Dx 45 starter clicks.
   / Dx 45 starter clicks. #1
compact freak
dx 40 case ih
Have a dx 45 with 6000 hours on it. Installed new starter but starter still clicks. Can jump starter and starts every time. Sometimes it will stop clicking or will start. Seems to be worse when engine has been running.
   / Dx 45 starter clicks. #2
have you checked the battery and/or battery cables?
Just cleaned both and seems to work. Not sure if that was the problem.
   / Dx 45 starter clicks. #4
Probably it was the issue and possibly you didn't need a new starter at all.
Diagnostically, you seem to have started at the wrong end of the trail.
:wrench:
   / Dx 45 starter clicks. #5
I always suspect the ignition switch, that is where I would have started.
Going to try switch still acting up. Thanks to all.
Not the key switch!! Would never be that easy!! Anymore ideas?
   / Dx 45 starter clicks. #8
How many volts is the battery putting out, clean and tighten the cables. Have you checked the ground where it connects to the chassis.
12.9 at cable at the starter. 11.6 at little wire at starter. Cables are tight at battery
   / Dx 45 starter clicks. #10
The starter solenoid is worn out.
2012 Ram 3500 Crew Cab Flat Bed Truck (A50323)
2012 Ram 3500 Crew...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2020 Ram 1500 4x4...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2015 Chevrolet Cruze Sedan (A50324)
2015 Chevrolet...
2012 International 4300 Reefer Truck (A52748)
2012 International...
