What internally does the High/Low speed switch exactly do?
I know what it does..but does it do something in the hydro system high speed bypass or is it a hydraulically activated planetary gear like some of the older tractors had.
Reason I ask is I have been traveling across a field with the switch in the high speed position and came to a ravine I needed to cross, coming to a stop. When starting again the hydrostat pressed and the engine really did not pull down but the rear tires didn't move. Obviously switching ranges it crawled right out. Is this normal or is there a planetary clutch going away or something. Obviously I know not to do that.
Question 2. Tractor is sometimes difficult to get into or out of 4wd. It seems more like the linkage is binding or something then sometimes it seems to move back an forth with ease. Even rocking the tractor back and forth seems not to make much difference. Seems more like linkage bind.
Thanks in advance.
Charlie Peters
Thanks in advance.
Charlie Peters
