Jerry/MT
Elite Member
- Joined
- Feb 2, 2008
- Messages
- 3,141
- Location
- North Idaho-The Palouse
- Tractor
- New Holland TD95D, Ford 4610 & Kubota M4500
And of course as volts go down, current goes up. QUOTE]
Can you explain what you mean by this statement?
I think it's possibly the additional current by the inductive load of the starter motor and the interaction of the armature and fields. An inductive load initially has high resistance until the magnetic field is maximumized and then effectively low resistance. If the motor doesn't turn, the load goes to maximum and stays there. Essentially, because of lower voltage, the motor doesn't have sufficient torque to turn the engine at normal speed. Starting current is high for a longer period of time, causing even a slo-blow fuse to pop. If the battery is hot enough to get the starter and engine spinning rapidly, the full torque requirement of the motor is reduced, allowing it to spin at higher rpm but not in a steady high current state. This is a bit of an oversimplification, but I don't think it's too far off.
Nope. Not an oversimplification at all Jim. Right on, except for the use of the term "high resistance" in the second sentence, as the correct term is high impedience which reflects both the resitive and inductive loads. As you note, the high current stays for much too long (due to not turning, or the operator continuing to hold the key) and the fuse heats and blows. The fact that the current is initially slightly less due to the low voltage (as you and others have noted - this is Ohm's Law) is negligible and far outweighed by the substantial length of time. In fact, if the fuse didn't blow, there's a good chance the motor would overheat and fail.
