Mowing Dust mask when mowing in dry conditions.
   / Dust mask when mowing in dry conditions. #1
BamaRob
Platinum Member
Alabama
Mahindra 2615 4WD
Do you wear a dust mask when mowing in extremely dry conditions?
I decided yesterday was a good time to mow down below the dam on my dad's pond. Most of the time, it's too wet to mow in there without marring up and creating a big mess. It hasn't rained in over a month, so the ground down there was nice and firm for the most part (only a couple soft spots that didn't cause any problems). Unfortunately, the dry conditions meant that there was lots of dust and pollen. I have lots of problems with my sinus allergies, and after mowing yesterday, I was feeling pretty rough last night and this morning. I got a steroid shot this morning and am feeling much better now.
So, do you guys/gals (especially those with allergies) use the paper dust mask when mowing in dry conditions? Do they do any good? Are there better alternatives?
Thanks,
BR
   / Dust mask when mowing in dry conditions. #2
The problem with a dusk mask is that they don't fit well so you suck a lot air through the gaps. Even if it did I'm not sure it would filter the pollen. A respirator on the other hand fits very well and you'll need the correct cartridge.
   / Dust mask when mowing in dry conditions. #3
I started having this problem with all day weed wacking and then brushhogging so now I take the benadryl anti-allergy pills and wear the cheap dust mask. Between the two I have no more issues. I was actually getting the swollen throat thing the night after the exposure. Unpleasant. I now also have the epi-pens for severe reation if I think I'm going to die but that is more for bees.
Now that it is the wet season, the dust masks don't get used.
   / Dust mask when mowing in dry conditions. #4
I usually ride with a damp shop cloth for cooling my forehead, but will put it over my mouth and nose when the dust kicks up. Really makes a difference when the allergies kick up.
Now where's that little yellow face for sneezing? /forums/images/graemlins/tongue.gif
I take Zyrtec daily to help control my allergies. I can't take Benadryl due to my high blood pressure (I take Atacand daily for that). The Zyrtec works well except when I do something stupid and expose myself to massive amounts of dust/pollen. So, the cheap dust masks seem to help you? That's good to hear. I'll give them a try next time.
</font><font color="blue" class="small">( Now that it is the wet season, the dust masks don't get used.)</font>
The wet season should be beginning here, but we haven't had a measurable rain at my house since shortly after Katrina went through! We could really use a rain. Both to settle the dust/pollen and to help my gameplot grow. /forums/images/graemlins/laugh.gif
Thx,
BR
   / Dust mask when mowing in dry conditions. #6
Yes, they help. I also wear the safety glasses during the weed wacking which presents a problem as the dust mask would channel my hot breath into the glasses and fog them up. The masks got dirty from filtering, and without the mask I would have inhaled all that stuff.
Funny thing about benadryl is that the alcohol hits you much quicker. Antihistamine/alcohol I should have known. I can only vouch for a benadryl/dust mask/alcohol combination. After one night of near panic when I couldn't breath very well I have really tried to tackle the problem.
   / Dust mask when mowing in dry conditions. #7
I've used the paper dust masks but find that a handkerchief tied as a triangle around ones head works just as well, without as much fogging of glasses. Most handkerchiefs aren't as big as the ones the cowboys wear for this; so my wife made me some out of rags.
Ralph
   / Dust mask when mowing in dry conditions. #8
I use a higher grade paper mask if it's really dusty (I'm lucky, no allergies). Also use it when doing demolition work in my business. It's thick foamy-type paper with a foam edge - where it makes contact with your face - and has a metal tab that you pinch over your nose (helps keep the breath from fogging saftey glasses that another poster wrote about). I get them by the box, 15 to a pack, I think, at Home Depot. Less than $1 piece in bulk.
-Norm
   / Dust mask when mowing in dry conditions. #9
Wear one whenever there is any dust (which we get a lot of post the Cedar fire).
Found that the best mask is one that has both a metal nose clip and foam pad at the top -- makes it more expensive as well.
I use an N-95 mask with an exhaust valve -- reduces fogging of the safety glasses and also keeps it cooler. Buy mine through www.gemplers.com.
   / Dust mask when mowing in dry conditions. #10
I've never worn a dust mask, but I notice when I mow ragweed, or weedeat weeds, I have difficulty breathing. /forums/images/graemlins/frown.gif
Trust me, that ain't fun. /forums/images/graemlins/crazy.gif I have an inhaler that I'll use on occasions like this.
RedDog
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2012 Ford Escape Limited SUV (A50324)
2012 Ford Escape...
CUSTOM TRAILER (A51242)
CUSTOM TRAILER...
1994 Toyota 6000lbs 2 Stage Forklift (A52128)
1994 Toyota...
2023 KUBOTA SVL97-2 SKID STEER (A51242)
2023 KUBOTA...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
