Dust Boots on Tie-rod ball joints
   / Dust Boots on Tie-rod ball joints #1
RayIN
S. Indiana
2003 MF 451
Something happened today I've never experienced. I was brush-hogging tall, thick Multi-Floral Rose bushes. When I stopped and returned the tractor the the garage, I used a leaf-blower to remove the pollen, leaves, dirt, and trash from my equipment. Then something shiny caught my eyes, it was both ball-joints. At first I though they were failing so I shook the tie-rod and it was solid.
Then I realized the thick brushy, thorned, bushes have torn off the rubber dust boots from the ball-joints.
I suspect this happened because I used the FEL bucket to push the stuff down and find hidden obstructions. I know replacement boots are sold, I just have to find where and the price.
I never did like replacing ball-joints, now I have 2 to remove and replace.
   / Dust Boots on Tie-rod ball joints #2
Pull the cotter pin, back the nut off and leave it on but proud of the top of the thread's and give it a good tump with a 5 pound drilling hammer and it will pop right out.
   / Dust Boots on Tie-rod ball joints #3
I like to turn the castle nut over and whack the flat side.
   / Dust Boots on Tie-rod ball joints #4
Good idea as well, not sonething I considered but I've never had to hit them more than once and not overly hard either.
   / Dust Boots on Tie-rod ball joints #5
Your not the first.
They come in all sizes, I got some from "Energy -Suspension" but that was many years ago.
This search string on any engine will return way too many options. ;-)
"tie rod rubber caps"
   / Dust Boots on Tie-rod ball joints #6
I never pound on the stud when removing a ball joint, unless I am replacing the ball joint. Don't want to distort the threads.
I always whack the side of the joint where the stud goes through, that usually will pop it loose after a few good whacks. I leave the nut on loosely in case I miss and hit the threads.
   / Dust Boots on Tie-rod ball joints #7
You can also buy a specialized puller to put some pressure on the stud when you hit the side. This can be necessary on the occasional stubborn one. The pullers can be obtained inexpensively.
   / Dust Boots on Tie-rod ball joints #8
The taper on most tractor tie rod ends is short and yes, wacking the side of the casting also works but a sharp wack on the threaded end with the castle hut installed so as to not deform the threads. ALWAYS works.
Far as boots go, I also had that issue some years back and I replaced the boots with sections of bicycle innertube cut to the correct length and zip tied to the joints. Still intact and working years later and a cheap fix. Recently replaced the OEM no grease ends with new OEM greaseable joints.
O'Relliys auto parts store has a huge on-line selection of dust boots. Now I have to go measure so I but the correct size.
I have a 3# brass hammer that will work fine.. I use it when I don't want to mushroom something; plus it's a deadblow action. I've had it for perhaps 50 years, couldn't afford a new one today.
Had I not still used the preventative maintenance taught me in the army, i might not have noticed the missing dust boots as soon as I finished with the tractor that day.
That reminds me, I gotta lube them with silicone before next use. That's what Reyco-Granning front suspension mfgr. recommends for their HDT front suspension sealed ball joints when the boot is compromised.
   / Dust Boots on Tie-rod ball joints #10
Great timing of your post. I just saw that my tractor has the boot split. Had no idea you could just replace the boots. I will get me two and do just that.
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
2025 New/Unused Wolverine Pallet Fork Frame (A51573)
2025 New/Unused...
2023 JOHN DEERE 8R370 LOT NUMBER 219 (A53084)
2023 JOHN DEERE...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
Year: 2017 Make: International Model: DuraStar 4300 Vehicle Type: Truck Mileage: 45,026 Plate: Body (A51692)
Year: 2017 Make...
