Dumping offroad military trailer
/ Dumping offroad military trailer
Thank you! At an extremely leisurely pace, it may take a min. to dump the trailer. The "holder" pin has to be removed, I use a bungee chord to tension the upper portion of the jack to keep it from flopping around, so that has to be removed, and my Highlift has a handle isolator that needs to be slid up the post. I pretty much jack until half way, then need to get up on the trailer's frame to finish the other half as the handle raises with the dumper. I would guess that at most (when 1st starting) it probably takes 75lbs of downforce on the jack's handle... and that becomes less as the dumper becomes more vertical. Perhaps I'll try to make a video with a load of snow once she's back together and out of the garage. LOL
Trust me... I don't have $2500 kicking around either. This was $300 for the trailer here, $120 for tires there and so on for three years. LOL It all adds up.
I plan to go visite the original owner with it in the spring. He was a pretty cool old fella that liked tinkering too.
/ Dumping offroad military trailer #22
I thought of that. It's main purpose will be gravel and crusher dust. Worst case with those will be a couple handfulls left behind. I could also just put some angled sheet steel to defelect material.
they make agricultural dumpboxes tapered to make them empty easier... your deflectors would still have the taper the other way around ;)
Drilled though the gate to instal the U bolts... welded to the square tube. Welded the quare tube to the plate some more while I was there.
Ta da!
One minor drawback is that the chains have to be pulled in in order to close the gate
Finished the square tube upper edge
I suck at matching up miters... don't look too close LOL
Patched up some holes
and started to reinforce the gate. I used 1X1/4" angle just because that's what was in my stockpile. I would have rather 1/8"
I'd like to do the same to the bottom, but it would keep the gate from dropping down all the way. I'll figgure something out. May weld some of that round tubing to the crossmember so the gate's edge would sit on it in the horizontal position, but slide over when folded down.
/ Dumping offroad military trailer #24
nice build. I used a boat winch to dump the one I built. Works great. I course I have to hand crank it up, but it is easy.
Upper hinges and pins
grab hook for adjustment and u-bolt
The pics suck because my two year old messed up all the settings on the camera
Thanks! Tomorrow's payday and I have it off, so I'll be picking up some supplies and hittin' 'er hard! : )
/ Dumping offroad military trailer #28
When you have a cubic yard of sand/crushed stone etc in that slick lil thing its gonna weigh about the same as your TJ or my JD4300. Plenty to be cruisin MY trails with.....
/ Dumping offroad military trailer #31
This trailer is truly a labor of love. Nice work. And good documentation!
Thank you very much deezler!
I kinda forgot about these... they'd developed a fair bit of surface rust with only about a year... though I do remember that I just rattle canned them and it's been my experience that rattle can just doens't last compared to brushing. So, flappered the rust off, prepped and primed.
She's outside for the first time in a long time
That's it! I need those wheels to be black too. Looking into Duplicolor Plastikote.
Should be getting my sheet of plastic this week.
Just called about uhmw, puck board is 1/3 the price at around $100/ sheet. I'm going with that. LOL
Step 1; thick coat of rust check
Step 2; plywood
Step 3; puck board, SS lag bolts, and seam sealer
Even got some use out of it today!
/ Dumping offroad military trailer #36
Nice work. You said you learned how to weld while doing this project? The welds look pretty good.
/ Dumping offroad military trailer #37
Very nice build. You will be suprised at the number of people who will think that you bought the tires and rims just for that trailer.
Thanks guys! And as a matter of fact I did buy the tires and rims just for the trailer! LOL $120 for the tires, and $240 for the wheels.... the wheels did match the Jeep's at that time.
Sheds the snow pretty good!
On our way to walk the "twail". She asks almost daily. She's carrying peanuts to feed her pet squirel Nemo.
I'm excited that she already likes the trail and that it'll make lots of good memories of her childhood : )
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Mini Margaritaville Truck (A55853)
Mini...
78" BOX BLADE (A60430)
204549 (A52707)
204549 (A52707)
2013 CATERPILLAR 308ECR EXCAVATOR (A60429)
2013 CATERPILLAR...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
