Dumped all but a gallon of hydro fluid, what are the chances I did any lasting damage
   / Dumped all but a gallon of hydro fluid, what are the chances I did any lasting damage #1
breadtrk
Platinum Member
ashland city, tn
XR 3037 HST Cab
I have a thread in the LS forum http://www.tractorbynet.com/forums/ls-tractors/313830-xr-3037-similar-owners-watch.html
Quick story is busted the HST filter open and really didn't notice till it started stuttering when I pushed the forward pedal. Then I figured out what happened.
I shut down till I fixed it and leak tested. Everything seems to be running like normal again. I am wondering if this was like running an engine without oil? Have I reduced a 50yr machine to 5?
   / Dumped all but a gallon of hydro fluid, what are the chances I did any lasting damage #2
I doubt you did any damage. Engine has pressure lubrication while the pumps are just flooded for lubrication. Also consider the temperature, forces and speed of moving part in engine versus the HST system I think you will not see any difference.
   / Dumped all but a gallon of hydro fluid, what are the chances I did any lasting damage #3
Most, if not all, tractor hydros of this size stroke the swash plate with hydraulic pressure from the charge pump. No oil, no pressure, problem immediately noted. At this time all the hydro components should still be well lubricated so unless you let spin for a long time after it comes to a stop, you have likely done no damage.
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATE (A54757)
UNUSED LANDHONOR...
2006 MACK MR CAB & CHASSIS (A54607)
2006 MACK MR CAB &...
2015 Ford Focus (A51694)
2015 Ford Focus...
UNUSED LANDHONOR LHR-BLC9021 TOOL STOOL (A54757)
UNUSED LANDHONOR...
