Dump truck
/ Dump truck #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
'nough said:)
/ Dump truck #4
Wow, what a thrill it would be to stay in the truck!
/ Dump truck #5
Sure would be a good test to see how good the brakes are. I wonder if the driver has to have his underware checked before he leaves for the next trip.
/ Dump truck #6
Looks like a good way to clear the "junk" off the dashboard. Interesting pic. I knew they dumped trailers like that but had no idea they did the tractor as well.
Al
/ Dump truck #7
Hehehehe. That brings back fond memories of driving a 12 yard dump truck for a construction company in the summer in the '60's. Most of us were college students. Anytime there was a new driver, we all looked forward to the first time he forgot to open his gate before dumping. The truck would slowly go to nearly that angle. You'd have to be pulled down. Very humbling. Yes, it happened to me too.
/ Dump truck #8
Reminds me of the grain elevator we had nearby when I was a kid. If you didn't have hydraulics or an auger on your truck, no problem, just crack the tailgate they'd dump the soybeans for you. Fun ride for a 7 year old.
/ Dump truck #10
And it still happens! :D
A couple years ago, while our house was still under construction, a driver tried to dump a load of fill with the gate locked. A few minutes later, I arrived to find the Mack 10-wheeler looking skyward. :rolleyes: Luckly, a friend came by with his D8 on the trailer & stopped to help. We gently pulled the truck back down, but the body refused to come down, so we had to YANK the truck down. Wouldn't have been near as stressful as it was if the dumper wasn't already too close to the new house, & if it wasn't already leaning towards the house! :eek:
/ Dump truck #11
czechsonofagun said:
'nough said:)
Wow! That's about a 150% grade.:rolleyes:
Considering that's a belly-dumper truck, I wonder who or how they got the rear swinging doors open before raising the truck? That must be an exciting job too.
/ Dump truck #12
If it isn't a bottom dump, that is the way the poultry companies dump grain around here.
/ Dump truck #13
I'm sure the lift operators have seen it a hundred times but they don't tell the green horns the first time they come in there with a load of grain at the grain bins, that the blocks that come up out of the ramp to block the trucks rear tires will rip the mud flaps off if the flaps are between them and the tires. They watch the green horn pull off to the side after he gets unloaded and puts the mud flaps back on, second trip, green horn knows to stop so the block goes between the tire and mud flap. But green horn gets out of the truck before the lift goes up, he ain't stupid!!!
/ Dump truck #14
Ocean Spray, out in Cape Cod, has been doing this for years, When you see a rig tie down, then the platform lifts rig and all, it is shocking to watch the first time
/ Dump truck #16
Its a chip truck(wood chips) the trailer s a rear swing door not a belly dumper just has a very low center of gravity. These boys flip over often round nor cal and they are loaded to the top! familiar site. Yes very exciting to watch unless you stuck behind one on the road.
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
JOHN DEERE 925F - 25' GRAIN HEAD (A64277)
JOHN DEERE 925F -...
New Holland C232 (A64126)
New Holland C232...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2025 Polaris Ranger Premium (A60462)
2025 Polaris...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
Here are some similar links:
  • Article
Trucks & Vehicles Ford Dump Truck (A64127)
  • Type: Trucks & Vehicles
Replies
0
Views
14
  • Article
Replies
0
Views
67
  • Article
Replies
0
Views
50
  • Article
Replies
0
Views
101
  • Article
Replies
0
Views
93
