Dump Trailers
   / Dump Trailers #1
tractorkid
I am thinking about getting a dump trailer. I'm am yet to do any research other than looking at some manufacturers websites. Just curious how well they work. My thought is to use it for mulch, dirt, brush, etc around the yard and some work going on the street. I have a trailer right now and use it all the time but waste so much time unloading it so was thinking that a dump trailer woulld be a good investment. For those of you that have them, are you happy with them, do they work well? Also, I dont need too big, or heavy duty, do I go 1 or 2 axles. Also, if you don't mind sharing, what are some of the price range you guys have paid in.
   / Dump Trailers #2
I'll offer some insite as I'm on the same quest just further along. I've found that dump trailers are a great tool and make lots of sense. You just need to see if the justification is there. Here's the pros, you can haul any bulk material whenever you like and avoid the high delivery prices. If you get a large enough trailer you can also haul your equipment. All the trailers I've looked at were very well made (brimar,ezdumper,premier,loadtrail,anderson,etc)
The cons I have found was price, and weight. These trailers weight alot. I have a 3/4 ton diesel so I'm not worried too much. The other con is size,I have a JD 3320 with fel and soon bh. The trailer I was interested in was 7x14
the tractor would fit well but that means I can't take any other toys(quad,mowers,etc) or attchments along with me. So at this point I'm leaning towards the flat deck trailer 12k 18'long with landscape stlye ramps. If I were you I'd go with tandem axles. Hope this helps.
Matt Traficante:D
   / Dump Trailers #3
I use mine mostly on my property, rarely on the road. Because my tractor is so small, it cuts a lot of hauling hours off it. I use it for spreading gravel from bulk pile, brush, dirt, excavated rocks, cut native grass for compost pile. Really really handy.
It's tandem axle w/brakes on one axle, 5'x10'x2' high w/stake pockets for sideboards, 7K# GVW, 2200# empty, elec/hyd power, single conventional ram (not telescopic, no scissors), barn style rear doors. About $2400 from a local mfg.
   / Dump Trailers #4
I just bought a Homesteader 6X10 tandem 10,000 lb capacity for $3900
I have looked and thought on it for years. Finally had the extra cash in hand to either buy the pieces, or go ahead and just buy the trailer. Looked at how long it takes me to do projects, and figured I would concentrate on things I HAD to do, and just buy the trailer.
Consider carefully what you will dump and the tailgate option. I have the tailgate that works like a pickup, or like a dump truck, but NOT like a barn door.
Already a couple of times I was wishing for the barn door option when unloading debris. It may be a mod in the making, but I want to give it a good try first.
I would not consider anything but a tandem, and I went with the heavier axles and smaller body as we have employees using the equipment and some of the things that stay on the front of my mind (like the weight of gravel) sometimes goes right past employees. I was considering getting the 3500 lb axles but as my dad said, how long do you think it will be before you see the trailer with 6000 lbs on it..... NOT long is my bet. Same with a bigger box.
I considered bigger, longer, gooseneck etc. but went bumper pull for ease of getting in tight places and variety of trucks I can hook too.
I have an 18' gooseneck equipment trailer that is still too short too often so I did not want to haul my epuipment in this trailer.
It is all a series of compromises, I bought the one I could afford, in the size I thought MOST usefull for us, at the place that had them at what I considered a reasonable price.
I will say it put a real big smile on my face the first time I had to unload a bunch of debris at 9 pm after driving 4 hours and working all day..... Hardest part was setting the chains, the rest was just a big smile on my face!
   / Dump Trailers #5
I have a 10 ft gooseneck dump trailer rated at 15,000;bs. I've hauled 12,000 lbs of 2b up steep mountains with no problem but the truck really had to work.
A couple things I hate about mine.
1.) the battery is not enough to dump the trailer near enough for it to be useful. What I really need is to be able to use my generator to power the hydraulic pump. The batter dies pretty quickly.
2.) I wish the axles were futher back. Its very difficult to back up.
   / Dump Trailers #6
What if your battery was connected to your trucks battery like campers do? and how about a larger capacity battery, like a deep cycle etc. they use on bass boats.
Jim
   / Dump Trailers #7
I don't own a dump trailer but I have used rented ones for different projects. They are wonderful things and have saved me a lot of time and energy. I started out renting open Uhaul trailers and using the tractor (when available) to unload but many times I was delivering materials to places other than where my tractor was.
A few thoughts about dump trailers:
1) they are very heavy- cuts into the load capacity and is a trade-off.
2) I have rented a Texas Bragg DT that I had to start unloading by hand several times because the hydraulic lift was unable to lift the load, (even though the load fit into the box) Have had better luck with a Bri-Mar
3) don't count in carrying large pieces of equipment because the dumptrailers are so much taller and harder to drive up into and out of. I have lifted the back tires of my trailblazer many times when unloading the dumptrailers as the load shifts.
W
   / Dump Trailers
Thanks for all your responses. So far I've looked at Bri-Mar, Cam Superline, and Downeaster. They all look well built, though the Downeater's don't seem to tilt as far as the others, though that could just be the photos, any opinions on this. Also, the Rascal series from Bri-Mar seems appealing. Though I am yet to get price quotes, they say it is their economy model perfect for the farm so I am thinking that may make sense to me as I am using only for personal use around the house carring dirt, mulch, logs, brush, etc. I also don't need too big as this isn't something I'll be using all the time. Anyone have any experiences with any of these brands?
   / Dump Trailers #9
If I remember right, the Bri-mar Rascal came with removable stake pocket sides.
I could see that being nice if you were doing a lot of palletized materials to get them off the sides.
I felt for the limited amount of palletized materials that we do, we could just load / unload them from the back.
I went with a deck over so that I had higher dumping heights. (and I still wish it was higher when dumping)
   / Dump Trailers #10
I have an Anderson 12k pound dumper that I use to deliver firewood. I tow it with my Ford Excursion on the road and with my Cub 7360 around the farm. I've delivered well over 100 cord of wood, plus use it to move brush, manure, mulch, etc. I used it today to pick up a load of hay and shavings at the feed & grain. It has been an excellent performer.
I bought mine on eBay. It was a year old and in very excellent condition and I paid slightly more than half the cost new. Mine has a single cylinder (I've seen some double cylinder units) and the bed goes up to about 50 degrees. The deep-cycle battery is mounted under the bed and I charge it throught the 7-pin RV connector on the truck. When I haul it with the tractor, I do not have the lights or battery hooked up. I can dump it 3-5 times before I need to put it back on the truck to charge. Obviously, dumping firewood eats up a lot more battery than dumping brush or mulch. I did wear out the original hydraulic pump and motor. The replacement was about $750 installed.
Mine has the 2-way tailgate with a side hinge and a top hinge. So the gate swings open to the side or you can release the bottom and let the tail swing like a dump truck. I do wish I had the barn door tailgate. Mine did not come with ramps, so I have not hauled my tractor with it. (the Cub has never needed to go to a dealer {knock, knock} ;) ).
All in all it's a valuable piece of equipment that I could not do without.
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
Ford Pickup NR (A50323)
Ford Pickup NR...
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
