Dump Trailer to haul rk24
   / Dump Trailer to haul rk24 #1
scottz
Big Lake, MN
RK24H
I am looking for the smallest dump trailer to haul an rk24. Has anyone come accross anything creative and econimical?
   / Dump Trailer to haul rk24 #2
I may be able to assist by providing dimensional information on the RK24. Tractor weight with loader 2091 lbs, overall length with loader 136.5", width with bucket 50", backhoe weight 1120 lbs, mower weight 271 lbs., mower width 73.6". My advise is to not select any trailer that is not safe and/or has marginal payload capacity. I like to have 50% more payload capacity than the payload.
   / Dump Trailer to haul rk24 #3
I just measured my RK24 and with FEL and backhoe measures 170" (14.16') to the back of the hoe if you swing the hoe left or right during transport.
Without the backhoe it's 150" (12.5') to the end of the lift arms.
With the backhoe stabilizers it is about 65" wide and about 63" wide without.
Hope that helps with the right trailer decision. (A dump trailer with 2' sides - 16' would work & 14' would be very tight if not too short without hanging over the ends)
I already have an rk24. I would like to haul it with the loader and backhoe attached.
For example, I found a 10’ dump trailer that would work for tractor and loader (no backhoe) by resting the front bucket over the front of the trailer.
I am curious to see what others have done.
   / Dump Trailer to haul rk24 #5
For example, I found a 10 dump trailer that would work for tractor and loader (no backhoe) by resting the front bucket over the front of the trailer.
This is my 10 foot dump,
If you leave the bucket hang over the front, simply leave the tailgate out, and haul the tractor with the backhoe,,,
Nothing says the backhoe has to be in the trailer,,
This trailer is 9,990 pound capacity.
   / Dump Trailer to haul rk24 #6
The backhoe needs to be secured to the trailer. Usually a strap. It can’t hang freely.
   / Dump Trailer to haul rk24 #7
I have a 12' dump, but I'm still waiting for my RK24 w/loader & hoe to arrive. I'll post up when I get it, should be this week sometime.
   / Dump Trailer to haul rk24 #8
picked up my RK24 today here are a couple pics in the 6x12 dump. the hoe is right up to the front of the trailer and the loader had to rest on the tailgate45005203_10161158090695512_62116926591074304_n.jpg44956553_10161159347240512_4453960465537564672_n.jpg
This is the first I have heard that the backhoe needs to be strapped down. The rk24 has a couple pins that secure the backhoe when not in use, does the backhow still need to be strapped?
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
2008 Ford F-150 Ext. Cab Pickup Truck (A55852)
2008 Ford F-150...
2022 Ford Explorer AWD SUV (A55853)
2022 Ford Explorer...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A55315)
2015 Freightliner...
Case Compact Wheel Loader Skid Steer (A55851)
Case Compact Wheel...
