dump trailer speed control
   / dump trailer speed control #1
windboarder
michigan
Kubota b2630
So im building a dump trailer/cart and my cart is dumping and lowering way to fast. I'm using a 12V Double Acting Hydraulic Power pack for all the Hydraulics. Is there any way to fix this?
   / dump trailer speed control #2
A bigger cylinder or a flow reducer.
   / dump trailer speed control #4
I’ve never had the need to do that but I think it would work. I think you’d only need one valve since of the fluid can’t move out of the cylinder fast more can’t move in fast. What kind of a setup are you using to be too fast? All of my dump trucks are slow.
   / dump trailer speed control #7
How big is the cart? I struggled making a flatbed truck dump with a 4 or 4.5 bore cylinder. My one ton dump truck is a 5” bore cylinder.
only about 1.50 yard and it only takes about 5 seconds to dump.
   / dump trailer speed control #9
For raise feature I would suggest a priority flow control. This style of valve bleeds the excess flow to tank.
A simple needle valve or orifice requires the pump to be at full pressure and dump the excess flow across the relief to tank. Using these for raise will result in excess heat, and various raise times depending on load in dump trailer.
how can i plumb the hoses to the reservoir or does it go somewhere else?
2011 Chevrolet Cruze Sedan (A50324)
2011 Chevrolet...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2015 MACK CXU613 TANDEM AXLE DAY CAB (A52141)
2015 MACK CXU613...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52128)
2016 Ford F550 4x4...
