Dump Hydraulics
/ Dump Hydraulics #1
joewilshire
Is it easier for a hydraulic system to dump a trailer load with a scissor type setup or just by pushing the bed upwards? I've seen both setups and was just wondering.
Thanks
Joe
/ Dump Hydraulics #2
A scissor type of lift will tilt the bed more vertical to clear the materials. The simple ram lift (cheaper) might need help with a shovel etc. If you put the rams further back for higher lift then the power required to lift a full bed may exceed available hydraulic power - no lift. Large dump trucks use a telescoping ($$) ram for height.
/ Dump Hydraulics #3
The scissor lift still has to be placed accoringly or it will do as the simpler ram system will do.
I do like a scissor lift myself although I didn't install one on my little 4X8 dump trailer since the lift alone would have cost almost as much as what I paid for in building the whole trailer.
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
Caterpillar 572E Tracked Pipe Layer (A64553)
Caterpillar 572E...
Mini Universal Root Rake (A65640)
Mini Universal...
2026 WINSTON 20 Ton Tandem Tag-A-Long Trailer (A62613)
2026 WINSTON 20...
2015 Ram 4500 Service Truck, VIN # 3C7WRKAJ9FG707673 (A65563)
2015 Ram 4500...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
