Dumb Question
   / Dumb Question #1
not2clever
NE Nevada
Mahindra 3016 Shuttle
Team:
I recently purchased a new Mahindra 3016 and only have about 10 hrs on it. I noticed there could be some sediment in the bottom of the fuel bowl and was going to clean it. I looked in the manual and it showed there is a fuel shutoff valve on the 3616, but could not find information in the manual for the 3016. The manual says to shutoff off the fuel before removing the bowl, but I cannot locate the fuel shutoff switch.
Thanks for your help.
Dave
   / Dumb Question #2
I am not familiar with your tractor, but if the manual does not show the location, perhaps you can call the dealer that you purchased from. If he doesn't know, one of his mechanics will surely know the answer . Good Luck.:tractor:
   / Dumb Question #3
Team:
Dave
The fuel shut off should be part of the filter assy. The lever should be on the aluminum casting.
   / Dumb Question #4
Dave,
I think your tractor replaced my 2816. I have not looked at that the 3016, but on my tractor the fuel bowl is directly below my fuel tank and fuel pump which is on the back. It does have a fuel shut off valve that is incorporated into the fuel bowl assembly.
This may not be much help, but I am sure Mahindra kept a few parts the same.
Nelson
   / Dumb Question
OK, Thanks for your suggestions. I will go have another look to see what I missed.
Dave
2006 Toyota Highlander SUV (A50324)
2006 Toyota...
44503 (A51692)
44503 (A51692)
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
17604 (A51694)
17604 (A51694)
2019 Bobcat S595 Skidloader (RIDE AND DRIVE) (A50774)
2019 Bobcat S595...
