dumb newbie question
/ dumb newbie question #1
webbmeister
Wauconda, Illinois
New Holland TC25D
When you buy a 3PH implement, does the hardware that cannects it to the 3PH usually come with? Is it attached to the implement in some way? Or was it supposed to come with the tractor?
Sheesh, this seems dumb - sorry. Gotta lnow though.
Thanks,
Jim
/ dumb newbie question #2
Not dumb at all.
The hardware will be with the implements, 99% of the time, more likely 100% of the time. The tractor has the 3pt hitch. The hardware has the pins the 3pt hitch hooks too. The tractor will have the toplink and the new implement will have a PTO shaft if necessary.
"99% of the time, more likely 100% of the time. The tractor has the 3pt hitch."
I deserved that. :)
Thanks Bo.
Jim
/ dumb newbie question #4
Jim,
Every implement that I have purchased so far has had the lower link pins supplied with it, but hardly any of them had the pin for the top link. I only have two top link pins and they came from my J.D. dealer when I purchased the tractor.
Hoss
/ dumb newbie question #5
just to restate what hoss said,the lower pins shold be with the implement, and if it is pto drive it should come with a pto shaft. top link pins and locking pins u have to supply, i normally keep a few extra around.
Thanks Hoss and Frank - Are these top pins something you got with your tractor? Or did you have to buy them seperately. I got two 3/8" pins with the tractor, but they don't seem sturdy enough for this purpose.
Thanks,
Jim
/ dumb newbie question #7
Jim,
Usually you wouldn't expect to get a top pin with the tractor, but that's not a biggie. (By top pin, I'm referring the pin that connects your top link to your implement) They're pretty cheap, maybe a few bucks. I know I have a few laying around of varying lengths that I have accumulated over the years. For Category I they're 3/4" diameter.
John
/ dumb newbie question #8
You guys need to get a dealer that takes better care of you. Every new implement that I've got came with a toplink pin.
Later
Mark
Well, we ordered a 57" First Choice tiller from Sweet today. We'll see how that theory holds up!
BTW - Ken Sweet answered all questions, and was a pleasure to deal with.
Jim
/ dumb newbie question #10
I recently purchased a post hole digger, I was sure to get extra shear bolts and an extra top link pin before heading home. To my disappointment the unit was shipped without oil in the gear box. /w3tcompact/icons/frown.gif Would not be so bad if I did not live 30+ minutes from nearest store.
/ dumb newbie question #11
the retired farmer that sold me the rough mower handed me some top link pins, and a handful of shear bolts too. [or is that sheer?] anyway, he just said, "here - you'll be needing these too until you learn what you are doing".
/ dumb newbie question #12
<font color=blue>To my disappointment the unit was shipped without oil in the gear box. Would not be so bad if I did not live 30+ minutes from nearest store. </font color=blue>
Would be even sadder if you hadn't noticed and started using the unit without the oil! /w3tcompact/icons/eyes.gif
/ dumb newbie question #13
<font color=blue>When you buy a 3PH implement, does the hardware that cannects it to the 3PH usually come with? Is it attached to the implement in some way? Or was it supposed to come with the tractor?</font color=blue>
The lower pins are usually attached to the implement, as in bolted or welded on. The top pins, in my limited experience, come only with some equipment. My JD and Land Pride stuff came with them.. but my King Kutter didn't. It remains to be seen if my Agri-Supply boom pole implement will be delivered with one or not.
I hope that helps. Best to have a few extras laying around, else you end up having to canabilize existing equipment to get a pin that fits. /w3tcompact/icons/wink.gif
Tiller came this morning. Lost a little paint along the way (so much for powder coat) but *did* have a top link pin. So, one for Sweet Tractors.
Regards,
Jim
1143 (A63745)
1143 (A63745)
2010 Dodge Charger Sedan (A66738)
2010 Dodge Charger...
2013 MACK CHU613 WINCH TRUCK (A67714)
2013 MACK CHU613...
Big John Semi Trailer (A65640)
Big John Semi...
2022 WESTERNSTAR DAYCAB 4700 CONCRETE MIXER TRUCK (A67714)
2022 WESTERNSTAR...
2014 DIAMOND C 45HDT CAR HAULER (A67714)
2014 DIAMOND C...
