dumb hydraulic control question
/ dumb hydraulic control question #1
tsterkel
North Texas
2202 Kubota
I have a left over 2000 pound cylinder from my FEL when I replaced both cylinders when one blew out and I could not find an exact replacement.
Here is my idea. the left-over cylinder would fit nicely in the same location as the current pain-in-the-@@@@@ 3point toplink, and could be used to make adjustments on-the-run, depending on ground conditions.
I have the links, clearances, and mountings worked out. Here is the question:
What type of hydraulic control box do I use to ensure that I put the cylinder to the right position and it holds it there until I change it.
I am assuming that I need a specific "type name"
/ dumb hydraulic control question #2
Knowing what machine you have could help us give you a better response, but in general you want a spool valve that is:
4-way
3-position
spring return to center
open center
possibly with a power beyond sleeve
1. glad I asked before just trusting joe-salesperson.
2. and I want all these or are some items mutually exclusive.
3. I told you that I am dumb....
4-way
3-position
open center
/ dumb hydraulic control question #4
You want all these.
Again: If you tell us what machine you have, or fill in your profile we can help better.
I can even point you to the exact valve you should purchase, but not without knowing the GPM specs of your machine.
ok, ok. It is a Kubota D1402 3-cyliner.
kennyd said:
You want all these.
/ dumb hydraulic control question #6
We need the tractor model, not the engine...
/ dumb hydraulic control question #7
Also, keep in mind, hydraulic toplinks usually have swivel eyes to provide for some lateral movement.
You will need to be cautious of this as your FEL cylinder probably doesn't have swivel eyes at each end.
here is a pic of a cylinder with swivel eyes.
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
2024 BOBCAT S76 R-SERIES SKID STEER (A64279)
2024 BOBCAT S76...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
LMC Ag 400 Gal Front Mounted Tank (A64119)
LMC Ag 400 Gal...
UNUSED ATSPOWER PROPANE PATIO HEATER (A64281)
UNUSED ATSPOWER...
