dualys on ih 254?
   / dualys on ih 254? #1
int254
ruffsdale pa
ih 254
does anybody know if i can put dual wheels on a international 254? if so how thanks
   / dualys on ih 254? #3
why duallies on a small tractor? I have thought about it before for traction, but it seems large ag tractors use them more for flotation. So do you want then for traction, flotation, stability... or what? Just wondering, not trying to talk you out of it.
   / dualys on ih 254? #4
I forgot to add, that I would think that on certain surfaces, duals would make traction worse- like with a dually pickup. Or am I wrong?
   / dualys on ih 254? #5
The dual wheels were on there when I purchased the tractor. The previous/original owner said he put them on because he had it fall over, yet he didn't add any rop!
I've now got the steel in stock to build a cage, but the weather here is awful, so may not get done for a while.
I have found on soft muddy ground, the 2" (50mm) gap between the wheels easily compacts with mud. I can get a lot out by using the back actor jack legs to lift the wheels off the ground, then running the wheels in top gear to 'fling' the mud out. If its allowed to dry, its a wheel off job to remove the soil.
   / dualys on ih 254?
looking for more traction because my property is all hills
   / dualys on ih 254?
that gets me thinking thanks looks good
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
2015 Ford Escape SUV (A56859)
2015 Ford Escape...
New Holland 1412 Discbine Pull Type Mower Conditioner / Windrower (A56435)
New Holland 1412...
22018 (A56859)
22018 (A56859)
