Tire Selection Duals
/ Duals #1
Buddycat68
Grayson ky
Massey ferguson 253,kubota M6040,New Holland TC40DA,Farmall Super A
I have a 2wd Massey Ferguson 253 with 14.9-28 R1 tires and I have found a set of reasonably priced clamp on T rail duals. The only thing that worries me is the duals are 16.9-28. Will these fit my tractor? I知 thinking the 16.9 are a little wider but that shouldn稚 be a problem because they are on separate rims??
/ Duals #2
What does your owners manual say about running duals. Mine says - NO.
/ Duals #3
Are the 16.9 taller? You do not want the dual larger diameter than the mains.
/ Duals #4
The tire height will most likely be different, it is not uncommon to run a slightly shorter tire on the outside dual of a tractor normmally that will be a worn one on the outside and a newer one on the inside.
for an example 16.9-28's from Titan run about 57 inches in diameter,
Products
While the same Titans in 14.9-28's are about 54 to 54.7 inches,
Products
/ Duals #5
Products
Products
