Tire Selection Duals
   / Duals #1
Buddycat68
Grayson ky
Massey ferguson 253,kubota M6040,New Holland TC40DA,Farmall Super A
I have a 2wd Massey Ferguson 253 with 14.9-28 R1 tires and I have found a set of reasonably priced clamp on T rail duals. The only thing that worries me is the duals are 16.9-28. Will these fit my tractor? I知 thinking the 16.9 are a little wider but that shouldn稚 be a problem because they are on separate rims??
   / Duals #2
What does your owners manual say about running duals. Mine says - NO.
   / Duals #3
Are the 16.9 taller? You do not want the dual larger diameter than the mains.
   / Duals #4
The tire height will most likely be different, it is not uncommon to run a slightly shorter tire on the outside dual of a tractor normmally that will be a worn one on the outside and a newer one on the inside.
for an example 16.9-28's from Titan run about 57 inches in diameter,
Products
While the same Titans in 14.9-28's are about 54 to 54.7 inches,
Products
   / Duals #5
Products
Products
2025 KMR 40in Single Cylinder Grapple Skid Steer Attachment (A51691)
2025 KMR 40in...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2018 Ford F150 4x4 Pickup Truck (A51692)
2018 Ford F150 4x4...
UNUSED X-STAR 20' X 101" LOADING RAMP (A51247)
UNUSED X-STAR 20'...
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
