calliesman
- Joined
- Feb 19, 2019
- Messages
- 9
- Tractor
- Cub Cadet 149, 147
Do any of you know how to get the adapter for duals on the rear wheels of a Cub 149?
I think you missed the part about, it's a GARDEN tractor, similar to the one in my pict...That method would get duals, but.
On most tires the sidewalls would be in constant contact rubbing and wearing,
also any dirt or grit that got between the tires would be eating at the sidewalls and chewing the tires.
I have had to pry and dig stones out of tractor duals and truck duals,
at times having to unbolt the tire to get them out and they have a gap that allows most trash to pass out.
Thank you. Do you think duals give more traction? Im installing a front blade and keep losing grip.
Thanks.
I did one with spacers, I added big washers with pieces of pipe between them, over the bolts to hold the tires apart...If those sideways touch and there is any flex its got to be rough on the tires.
I would add some kind of spacer to prevent tire contact.
