Duals or ballast
   / Duals or ballast
Well I started filling my tires tonight and I can't believe how long it takes. I'm using the well spigot and I thought it would only take a few minutes, but 30 minutes later I'm typing this while water is still going in the tire. I'm using the slime adapter from tsc.. I assume I'll know when the water gets up to the valve by pressing the pressure release and water should come out. The hole for water to pass through is tiny.
   / Duals or ballast #12
did you just remove valve core or the bigger brass piece
   / Duals or ballast
Valve core..
   / Duals or ballast
Sounds like I should have removed the brass piece.. I just heard it top the valve. Almost took an hour!!
   / Duals or ballast #15
You need to bleed the air often when filling a tire with a hose adaptor. As you add the water the pressure builds up in the tire slowing the water feeding into the tire.
   / Duals or ballast #16
And as the tire gets full. The more often you need to bleed. There is less room for the air and it compresses quicker.
   / Duals or ballast
I would take the whole adapter off and let it bleed out to a little less than 9psi or so, then back to filling. I'll probably do the other tire the same way. I'd rather not remove the brass piece and take a chance on messing up the valve. I can't wait to see how it hooks up with the added weight.
   / Duals or ballast #18
you won't mess it up, that's what its made for
   / Duals or ballast
I actually removed the brass piece tonight to fill and amazingly enough my valve stem seal started leaking after I put air in the tire.. Go figure. Now I gotta deal with this. I will be removing the brass piece from here on out for sure. Much quicker.
2017 FREIGHTLINER M2 106 (A58214)
2017 FREIGHTLINER...
Hustler super Z zero turn (A56857)
Hustler super Z...
2020 Ford F-250 (A55973)
2020 Ford F-250...
2006 International 9400i (A55302)
2006 International...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
Black Metal Roof Panels (A55758)
Black Metal Roof...
