Rotary Cutter dual mulch blades
   / dual mulch blades #1
OrangeToys
Platinum Member
SW Missouri
2016 Kubota M7060HDC
I've seen on some of the batwing cutters you can double up your blades to get a mulching affect. So that got me to wondering if you can do the same to the smaller decks too? I run a bb72x but I can't find anywhere that's says you can or can't. Has anyone tried it?
   / dual mulch blades #2
I too seen one the other day and wondered the same thing.
   / dual mulch blades
Anybody with experience
   / dual mulch blades #4
I've heard of guys doubling up on blades on ZTR's.
   / dual mulch blades #5
I run double blades on my lawn mower when the grass is really growing fast in the early spring to prevent stragglers.
Doubles on a rotary cutter would depend on the design of the stump jumper. If the stump jumper is a full heavy disc, it might be as simple as drilling 2 more holes to add the additional blades, I have seen these on several heavy duty cutters. On the other hand, If the stump jumper is heavier where the current blades attach and light where the new ones would attach, it isn't going to work.
We have a 7' Sidewinder that has a thick solid stump jumper, and a 10' Woods that has the stump jumpers U bolted to the bar that attaches the blades.
   / dual mulch blades #6
This is the way the ones I've seen mount.
   / dual mulch blades #7
I installed dual blades on my 38" JD lawn mower/tractor years ago. It worked great until I hit an unseen and hidden steel fence post and tore up two of the blades.
Where I live now, I really need the dual blades, it would work much better than the single blades I have now.
Just make sure that your bolt (or whatever fastener used) is long enough to accommodate the dual blade thicknesses.
Good luck!
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
Deere 335P (A53317)
Deere 335P (A53317)
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
MISC TIRES (A54757)
MISC TIRES (A54757)
Sunray Family Fisher 17.5 18' Pontoon Boat (A53316)
Sunray Family...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
