Dual filters for transfer tank
   / Dual filters for transfer tank #11
You should check with a boating supply place for a filter and fittings,
that is where I bought mine 15 years ago.
I never regretted buying the RACOR 500FG as we used them
at the mine where I worked because they prevented a lot of
fuel system damage because of the crap in the fuel tanks
and the water in the diesel fuel.
One complete canister with a stationary turbine vanes spins the dirt
and water out of the fuel and you can have a 2 micron fuel
filter that will last for 10,000 gallons if you are using diesel.
   / Dual filters for transfer tank #12
I just have a single goldenrod filter on mine. Never has anything in the bowl either. It's on a heating oil tank sitting outside, stored all kinds of wrong.
I am going to go that route. One filter that takes out water and 17 micron and bigger stuff.
Just need to decide if I want the spin on replaceable canister or the one with the plastic bowel and replaceable element.
   / Dual filters for transfer tank #14
I have used both. The spin on water block canister from goldenrod is 10u, but they are more expensive than the cartridge water block filter in the bowl. I personally like to see what's coming out of the tank into the sediment bowl filter.
Either filter will lockup solid with a big slug of water, or slowly restrict flow with lesser amounts of water.
   / Dual filters for transfer tank #15
Get the plastic bowl. If you dont see anything in there its prob not worth changing. I have changed that golden rod filter 1x in 5yrs. Granted it's only had 150gal through it but it is heating oil in a heating oil tank.
I go through 100 gallons a year. The storage tank is stored in the pole barn so it does not see the kind of temperature swings an outside tank gets.
   / Dual filters for transfer tank #17
I'm just using a golden rod. But I'm hand pumping into a tractor with a VE fuel pump.
   / Dual filters for transfer tank #18
404 nouser I had the owner of a Tractor dealership tell me one time in addition to filtration he also strained his tractor fill ups thru a pair of ladies stockings. Said he took no chances as high as this repair work had gotten. So I’m just about so careful I want to handle mine in 5 gallon jugs. But it’s a lot of work. Some of my stuff is tall, and I have to lift it with a bucket tractor
   / Dual filters for transfer tank #19
I need to level-up my system. I have the combo goldenrod water block filter, but I’d like to a an additional filter. No injector problems, but I don’t want any in the future, either. I do take some comfort in all my farm tractors having dual fuel filters, so that helps me sleep a little better.
   / Dual filters for transfer tank #20
Ok, I am a truck driver so keep this in mind as I go down a rabbit hole.
There are millions of trucks on the road. They all have a fuel filter that keeps the crud out despite the places we manage to find with bad fuel.
Somebody has to sell the replacement filters? Probably pretty widespread, I would think.
There are a bunch of trucks wrecked every day. Each of these trucks are either fixed or sent to a scrapyard as a parts donor. Somebody has to be selling these parts, somewhere.
I am thinking that I might investigate one of these dismantling yards to see what they want for the fuel filter setup. Got to be cheaper than new, I would think. Plus the filters are available at almost any truckstop or parts house.
What do you guys think? I plan on adding it to the fuel supply system on a 2003 Dodge Ram. The truck has been sitting for years, so there is a good chance there is water or other contamination in the system.
David from jax
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A56436)
2-Row Peanut...
2006 Dodge 1500 Pick Up (A55272)
2006 Dodge 1500...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
Hitachi 10 Inch Compound Miter Saw (A57454)
Hitachi 10 Inch...
