Dual Acting Cylinder vs. Single Acting Cylinder on Implements
   / Dual Acting Cylinder vs. Single Acting Cylinder on Implements #1
XxLT250RxX
Bronze Member
NW Alabama
On my previous tractor there was a screw on the valve that controls the rear remotes. Turn the screw in to control dual acting cylinders on an implement. Turn it out to control single acting cylinders. How does this work on my TYM built tractor? I don’t see a screw to switch it to single acting cylinders. FYI the equipment I am trying to use is a 2021 John Deere bush hog with a single acting cylinder to raise and lower the tail wheels.
   / Dual Acting Cylinder vs. Single Acting Cylinder on Implements #2
On my Kioti i had to add a return port to the transmission fill port. This is the same part you add if you install the backhoe. This accomplishes the single acting valve return path. No switching of valve controls.
Tandem 6 Lug Running Gear (A50774)
Tandem 6 Lug...
Skidloader Forks (A50774)
Skidloader Forks...
Kioti LK2554 Tractor (AS IS) (A50774)
Kioti LK2554...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
Vermeer 630A Stump Grinder (A50515)
Vermeer 630A Stump...
