dtc 4881 F 30
   / dtc 4881 F 30 #1
jalope
Kioti Ck4010
On my Kioti Ck4010 with 417 hrs the CEL came on and a dtc 4881 F 30 is flashing on the hours display. The local Kioti dealer can't get to it at this time, so does anyone know what this error code means? The tractor still runs, but the rpms are limited. Thanks for any leads you can provide.
   / dtc 4881 F 30 #2
The error code listed in your post is an "Injector Learning Condition" fault. You can take a look at the Injector Harness on the top of the engine and make sure you don't have a rodent issue. We find a lot of mouse nests on the top of engines, and they love to chew the injector harness. Other than that, this is probably going to be a dealer resolved issue.
Hope this helps
   / dtc 4881 F 30
Thanks for the information, I will check that out.
40' CONTAINER (A52706)
2009 Honda odyssey (A55788)
2009 Honda odyssey...
2014 FREIGHTLINER CASCADIA (A55745)
2014 FREIGHTLINER...
2023 John Deere 6155M MFWD Tractor (A53485)
2023 John Deere...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
Pallet of UV Solid Hardwood Flooring (A53424)
Pallet of UV Solid...
