DS4110 HS Fuel to injection pump then nothing
   / DS4110 HS Fuel to injection pump then nothing #11
These are common automotive-style relays and you should be able to get a spare at any car parts place, like Autozone, for example. Just make sure any spare is rated at the same or greater contact current of the old one. It is possible your problem was corrosion on a connector or pins and simply reconnecting wiped it clean. It's also possible you have a marginal relay that will require replacement in the future. In the mean time, attaboy!
LOT: Steel Work Table 36" x 72" w/8" Craftsman Grinder, (2) Lockers (VISE NOT INCLUDED) (A59076)
LOT: Steel Work...
1ft Bucket Smooth or Cutter Teeth (A57454)
1ft Bucket Smooth...
UNUSED FUTURE BK56 56" HYD BACKHOE DIGGING ARM (A58376)
UNUSED FUTURE BK56...
Aerway Tillage Tool (A59814)
Aerway Tillage...
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A56858)
2017 Autocar...
2012 Terex TA400 Articulated Dump Truck (A59213)
2012 Terex TA400...
