DS4110 Blowing fuses using PTO
   / DS4110 Blowing fuses using PTO #1
freddymac63
ideas on why my DS4110 is blowing the PTO fuse? I'm blowing the 10amp PTO fuse sometimes after a couple hours, sometimes immediately. It use to run several hours after I would take apart and reconnect the wire connector to the left of the fuse box, appeared dirty but not wet. Now it blows it immediately.
   / DS4110 Blowing fuses using PTO #2
Blowing fuses are caused by excessive current, often a short circuit, sometimes a motor or solenoid that is defective. I don't know that tractor at all, but I can give you some general guidelines for tracking it down.
See if you can disconnect the power lead right at the load (whatever is being powered by that fuse). If you can, now test the circuit for excessive current. You can either use a fuse, if you have plenty, or, use a test light across the fuse slot. If there is no current flowing, it should not light. If it doesn't light, the problem is in the load you just disconnected. If it lights, there is current flowing and you have a short somewhere in your wiring.
If there is a switch somewhere, disconnect the power side of the switch, and repeat as above. If the light still lights, your problem is between the switch and the fuse. If the light no longer lights, disconnect the downstream (load) side of the switch, reconnect the switch, and try again. If it blows now, your switch is the culprit. If it does not, the problem is between the switch and the load.
See the idea? Split the circuit up, and test each part. That will start to narrow down where the problem is.
great suggestion. I suspect its shorting through the connector, so I'll probably start there but I follow your logic.
   / DS4110 Blowing fuses using PTO #5
As you're chasing down the culprit, apply dielectric grease to all the connections to prevent future shorts, corrosion, or arcs.
2011 CHEVROLET EXPRESS SERVICE VAN (A57192)
2011 CHEVROLET...
2010 HEIL TOKEN TRAILER (A53843)
2010 HEIL TOKEN...
VERMEER 606 6" WOOD CHIPPER (A57192)
VERMEER 606 6"...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2008 Jeep Wrangler (A56859)
2008 Jeep Wrangler...
HAMM HD120HV DOUBLE DRUM ROLLER (A52707)
HAMM HD120HV...
