DS4110 Block Heater Installation
/ DS4110 Block Heater Installation #1
DavidAero
Canada
Kioti DS4110
Hi!
I'm new to this Forum. I own a DS4110 since last May and very happy. I will buy a snow blower (I've bought a 75" Meteor, but I saw some bad review on it, hopefully mine will be fine) and I decide to install a block heater. I've reading on the subject and some people seems to have issues with theirs pooping out. Hopefully won't happen to me. Since there are no instructions provided with the block heater I will post what I did, and maybe will help.
My first step was to empty the coolant. There is approximately 8-10 Litres.
After, I wasn't which freeze plug to remove, and I want to make sure I'm able to remove the starter without problem. So I did the exercise, I install temporary the bushing and look if the starter can be removed (I unplug the battery before).
The starter can be removed no problem.
Next is to remove the freeze plug. It is quite easy, you have to gently hammer the top of the plug and it will start to pivot, than you remove it with pliers by pulling the bottom. You need to dry the block and clean the area where there will be the bushing.
The next step is to clean the bushing and apply Permatex red thread locker or high temp silicone(I use silicone)
Install the bushing with a hammer and socket and an extension or in my case I have a bearing installer. Than install the block heather.
And I tie the wire as follow
Make sure the wire is not rubbing against the panel.
Let's hope it won't pop out. I tried it and it seems to hold so far.
Do you have any advice on purging the air from the rad? If I squeeze the top hose, I can ear air bubble, but when I remove the rad cap, it's full...
/ DS4110 Block Heater Installation #2
Hi, Welcome to TBN.
I'd leave the cap off and run the engine to get it up to temp to get the T-stat to open and then fluid/air should flow no problem. Then put the cap back on. Let it cool down significantly then SLOWLY remove the cap, making sure there is no excessive pressure from the possible still trapped air or unopened T-stat. For future reference it might be wise to find out which freeze plug to knock out from your selling dealer or on TBN. Some may have not enough open passage for the plug to fit into the water jacket, or may require a certain plug location for other reasons.
Good pics.
Thank you,
I've been letting it running for a while 15-20 minutes. As soon as the level started to get lower, I was filing it, but then start to expand. I put the cap back. I let it run, but doesn't seems to want to warm up. I used it a little bit, but I don't think it was enough, when I touch the block, I could leave my hand there... I will let it cool down over night and do the exercise with your advices tomorrow.
My dealer told me to put it on the driver side, but didn't mention which one. I've measure the dept, and the end of bushing is within the block thickness, it doesn't block the passage. Do you have a block heather on yours? Where it is install?
/ DS4110 Block Heater Installation #4
Yes, it's on the same side, orientation is from the operator's seated position, so driver's side would be left, in N. America, at least.
My model is the DK series, but it looks basically the same...
I would run it tomorrow morning and drive it around outside a little. Don't do any work with it until you get the temp gauge reading right, and the coolant flowing properly - hot top hose on radiator. You HAVE to get the air out before you run it too long without coolant flowing through the entire engine or you could do damage. I'd run it around 1200-1500RPMs for around 5-10 minutes and see where you're at with getting flow back to the radiator. I'd probably shut it down before 15-20 minutes so you don't generate too much un-disipated heat. Liquid MUST flow for the engine to cool properly. You may have to do this a couple of times to get it going...be patient.
Report progress/results.
When done check for leaks at the freeze plug.
/ DS4110 Block Heater Installation #5
When I did mine I reused the coolant to make sure I got all back in. There is nothing special about the cooling systems on the Kiotis, the highest point is the rad and a pressure refill is not required like some cars. If you are really worried, try this kit for refilling, works great for non pressure fill coolant systems...
Lisle 24610 Spill-Free Funnel : Amazon.com : Automotive
I have a Meteor too, and have been quite happy with it.
/ DS4110 Block Heater Installation #6
The trick with block heaters is not to run them too long. In other words, don't run it all night long. Just turn it on a couple hours before you need to start the tractor. Leaving it on too long just wears out the heating element and runs up the electric bill without making the engine significantly warmer. Some people use a timer to start the heater before the alarm clock goes off. Another thing that helps cold starts is synthetic engine oil which won't get as thick as regular oil.
/ DS4110 Block Heater Installation #7
David,
Did the heater kit come from Kioti?
When I bought my Dk40, my dealer told me that Kioti didn't offer a kit and said if I installed one of those heater it may void my engine warranty should anything go wrong. His recommendation was to install a lower rad hose heater, but I sooner use a proper block heater.
If your kit was from Kioti, could you share the part number? I got through last winter without a heater, but I would feel better if I could plug the tractor in on those really cold days.
Jason
/ DS4110 Block Heater Installation #8
David,
Jason
No, if you check my posts I link to a source for the heaters, a member on here that escapes me right now. Lower rad hoses are not as efficient as you lose heat through the radiator (it's doing exactly what it should, dissipate heat) while a block heater heats the block itself plus the coolant. As for warranty, only way that would stand is if it caused specific damage that could be traced to the heater itself. So do be careful on install, but don't worry about frivolous stuff like rejecting an drivetrain claim b/c of a block heater.
/ DS4110 Block Heater Installation #9
My Kioti dealer puts Katz block heaters in all the Kiotis he sells. I've never used mine to date, since I store her under a blankie in my heated barn.:)
Careful installation and you should be good to go. I'd set it on a heavy duty timer to trip ON at a specific time and then unplug it when wanting to start it - couple of hours at most on so as to not burn out the element from over use. YMMV.
/ DS4110 Block Heater Installation #10
Glad to see somebody with common sense . using a block heater instead of ether or tarps and a salamander.
Thank you for your help and advice,
I've been doing the cycle a few time and now it's seems ok.
David,
Jason
I bought my block heather from a Kioti dealer, it's Phillips & Temro p/n 3100002 and the p/n for the bushing adapter is C28125 (I don't know the manufacturer). I took some pic with a caliper. I would not use those pic to machine one though, it's not an accurate tool like a micrometer, I took them for reference only. The other reason not to machine one is I don't know which type of steel the used.
At the begin of the taper
in the middle (+ or -)
at the end of the taper
The freeze plug
Yes, and my tractor never sleep outside, always been stored in my insulated garage. My garage is too expensive to heated, I tried once and it cost 70$ of propane for 2 days (radiant heater, a tube hanging from the ceiling). I heat it only if when I work in it and it's really cold, below -20°C.
/ DS4110 Block Heater Installation #13
Bravo for your installation! I'm sure you will enjoy a lot your block heater when the old man winter bite hard! 30 minutes seems to do the trick for my little CK20. The block heater was installed @ the dealership prior delivery. I plug it in about 10-15 times per winter. For comparison last year I did try out a real cold start without the block heater, ouch.. a lot of black smoke, belly dance for pistons a shaky starts to say the least... And it took at least 10 minutes to work correctly. It's indeed a great add on!
Enjoy winter!
Enjoy winter!
Thank you,
I want my engine last as long as possible too. Can you post an other photo of your installation, it seem to be install on the small hose between the rad and the engine block.
David
/ DS4110 Block Heater Installation #15
The block heater on my CK27 came from the dealer installed. i turn it on about 2 hours before I want to start her up. I sure works better than leaving it plugged in all the time. That was a big time $$ waster last January.
/ DS4110 Block Heater Installation #16
Install a similar block heater in my DK40SE last weekend. Install almost identical to DS4110 Block Heater Installation. I had no issues completing the installation. I purchase my block heater from H&M Equipment Co though ebay. H&M Equipment Co shipping was really fast; I received my order in two days. Order Thursday evening, received Saturdays, and installed on Sunday. The heating bushing was inside 2 plastic bags. Outer bag indicated Tisco GE11461B GE361. The inner bag stated "Replacement 121247285 (AD0726)" UPC code 00736800 915858. The block heater is from Phillips & Temro Inc Zerostart product line is part #3100093. Phillips & Temro Inc catalog indicates it's 400 watts heater with ¾" NPT threads. The replacement cord part# 3600003. You might be able to save some money by purchasing the items separately. A quick search of Amazon and Ebay appears to indicate the total will be around $65 but will you receive and get the heater installed before spring? Ebay Link: Kioti Kubota Diesel Compact Tractor Block Heater | eBay
/ DS4110 Block Heater Installation #17
My tractor did not come with a heater, and I have not gotten around to putting one on yet, so if it is really cold, like below zero, I would resort to putting a salamander under a large tarp, please explain why this would mean I am lacking in common sense? I would say using any method available to warm an engine is much smarter than risking engine damage by forcing a cold start with no warmth.
/ DS4110 Block Heater Installation #18
Thank you,
David
Has anyone figured out exactly where this heated is installed? I like this install a little better than the frost plug install.
John Deere 4044R (A62177)
John Deere 4044R...
New Holland TC21 (A62177)
New Holland TC21...
2023 John Deere 6R 175 Tractor (A63111)
2023 John Deere 6R...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2016 F-250 4X4 (A56438)
2016 F-250 4X4...
