DS Right Front Wheel alignment Question
   / DS Right Front Wheel alignment Question
It's a simple matter to lift the front end with the loader and then rotate the wheel to see if it's bent and shake the wheel to see if something is lose. Your measurements should tell you something. Is the 4WD working correctly? I would think a major bearing or case failure would effect the 4WD.
A catastrophic axle bearing failure is all but certain to be accompanied by an oil leak. Checking for bearing play and bent wheel equipment are good things to do.
No oil leaks no squeaking or noise. I lifted the wheel this morning and there is no play and no wobble during rotation. I put the front wheels on a 2" x 10" timber hardwood beam to make sure it was dead flat and there is still an the problem consistent with the first few photos. I took some more which I'll load up when I get a chance but it is just the same as the first just taken in a different location and angles. Everything seems to working as it should 4WD is all ok, really after 26 hours I'm very happy with he tractor, but I like things to be right and this will drive me nuts not to mention if here is something serious. I assume it would be covered under warrenty, I let you know what the dealer comes back with next week. But any ideas or suggestions would be greatly appriciated. cheers!
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2009 Sterling Derrick Digger Truck (A55973)
2009 Sterling...
Electric Golf Cart (A56859)
Electric Golf Cart...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
1998 INTERNATIONAL 9200 TANDEM AXLE DAY CAB (A57880)
1998 INTERNATIONAL...
2011 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2011 Freightliner...
