Drywell, what is it?
/ Drywell, what is it? #11
OK, now that I've taken a class on this subject I can pitch in here. 1. Cesspools are illegal in almost all states now since they would often fail within a few years and discharge unwanted effluent onto the ground.
I can speak for the rules in NC, that say, any water that comes into the house needs to go out through the Septic tank and to the drainfield, although watersofteners are often exempt from this.
The concern for household wastewater these days is not so much for the pathogens, but more toward Nitrogen and Phosphorous that don’t break down in the soils and eventually make it into the ground water and streams and lakes. Nitrogen especially is finding it’s way into groundwater and causing excess plant/allege growth in streams and lake and thus removes the oxygen available in the water for fish and other creatures.
Of course most clothes washing soap is loaded with Phosphorous.
I’m not sure why you’d put gravel into a dry well, since your not really trying to filter the gray water in anyway. And you’d want that space taken up by the rock to be used for storage of the gray water.
Gary
/ Drywell, what is it? #12
<font color=blue>I’m not sure why you’d put gravel into a dry well</font color=blue>
Read this post as to why you should put gravel in a dry well<A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=powertrac&Number=139583&page=&view=&sb=&o=&vc=1> Click here </A>
/w3tcompact/icons/laugh.gif
/ Drywell, what is it? #13
OK, you got me on this one/w3tcompact/icons/wink.gif
I guess what I should have siad "a properly constructed dry well"/w3tcompact/icons/smile.gif Not just a hole in the ground covered with whatever was handy at the time.
gary
/ Drywell, what is it? #14
Way back when there was an Exploration Manager for one of the major oil companies based in Alberta That received the Name DRYHOLE ??????. This was cause all the wells he drilled were dry holes.
Egon
/ Drywell, what is it? #15
<font color=blue>"a properly constructed dry well"</font color=blue>
You got that right /w3tcompact/icons/laugh.gif One more pass and I would have lost my tractor for a while /w3tcompact/icons/smile.gif
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 MACK P164T (A60736)
2020 MACK P164T...
Informational Lot - Financing (A61307)
Informational Lot...
KBH Tank Trailer (A61307)
KBH Tank Trailer...
John Deere TX Gator (A60462)
John Deere TX...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
