Drywall surface - repair or replace?
   / Drywall surface - repair or replace? #12
If I'm using store bought mud do I thin it w/ water at all? Usually when I'm doing joints I "caress" the last layer lightly with a wet sponge before letting it finally dry to sand.
Personally I do not add water, I do use a mixing paddle on the end of a heavy drill to mix things up throughly though. Some do add water but remember as it dries it shrinks and the more water you add the more coats you will have to do.
MarkV
   / Drywall surface - repair or replace? #13
I've done a skim coat over top for a wall that had wallpaper removed. Then just lightly sand.
   / Drywall surface - repair or replace? #14
We are doing this at work all the time. It is a hotel and we are always stripping off old wallpaper, no matter how gently you pull sometimes some of the drywall paper comes off too. We just skim coat it over, sand it smooth, and then seal it with a paint primer. The surface s then good to go for either new wallpaper or paint.
Like you, I add a touch of water to the drywall mud, it makes it easier to work with and forces me to put down thinner coats.
   / Drywall surface - repair or replace? #15
It really depends on how big of an area and the degree of damage to the existing walls. I try to keep what's up there and patch it if I think that's the faster way to fix the wall. I know that if I put in new sheetrock, I have to feather all the edges and build it up to blend it to the exisisting wall, and that's three days drying time.
For the really bad areas, or if you want the best results possible, prime the exposed gypsum with a good quality primer. I like Zinsser 123 for sheetrock. It soaks in and locks it all together. Then it gives you a solid base to work from when adding your mud. I buy the lightweight stuff in the box with the blue trim. It sands the easiest.
I mix a cup of water into the box. I prefer box over buckets. It's cheaper and easier to work with. I never save any left over mud because it starts to smell bad fairly quickly and it's cheap enough to always buy new for each job. First coat is just to seal the tape and start the build up. Second coat gives me the level that I want. I sand after the second coat so I know where to work the third, and hopefully, last coat. Then I sand the third coat and texture.
The best sand paper is at Home Depot. I like the most aggressive paper I can find, and I like to change sheets as soon as I have to start putting effort into the sanding.
Be sure to use a straight edge, or 6 ft level to see where the high and low spots are. Use a pensil to mark those areas so you don't forget where they are.
Same thing with new sheetrock, except be sure to cut out the texture and a layer of paper on the existing wall so that when you put your tape down, it will be flush with what is already there. I only use fiberglass tape.
Good luck,
Eddie
Rooster Weathervane (A55853)
Rooster...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
