Dryrotted tire, can it be tubed or replaced?
   / Dryrotted tire, can it be tubed or replaced? #1
fatjay
Eastern PA
Not enough
One rear tire is leaking, can hear a hiss. It's falling apart and should be replaced, but as a for now fix, can it be tubed? It's 11x24 and looks like layers are coming off in places.
   / Dryrotted tire, can it be tubed or replaced? #2
It can probably be tubed for a temporary fix. You could also try injecting some tire sealant, slime, or fix a flat. Tire could also be foam filled. Ask the local tractor dealers maybe they would have a used tire.
If it's truly falling apart then bite the bullet and replace.
Thanks, of course when I realized it, it was a half hour after the tire place closed and they don't reopen until monday. I'm looking to buy the tractor, just trying to see how deep I'm getting in.
   / Dryrotted tire, can it be tubed or replaced? #4
I had a tube put in an 11x24 last fall. Cost $75 plus my labor and transportation. I'm gonna replace it in the spring. Yours sounds worse than mine.Might be better to do the job once.
   / Dryrotted tire, can it be tubed or replaced? #5
If possible I would replace the Tire you would be Money a head.
   / Dryrotted tire, can it be tubed or replaced? #6
Look for a used if money is tight. If its as bad as I think it is you should be able to find a better one.
Yeah, looking around they're not to bad. I was thinking it would be a lot more. Chunks the size of my fist could be pealed back, and after driving around, it had a loud hissing from a 6" long crack.
   / Dryrotted tire, can it be tubed or replaced? #8
Definately sounds like a replacement. If one tire is that way; if all are the same vintage, the rest are not far behind. If the same vintage I would plan my buy on getting 4 new tires. Might even be a bargaining point.
Ron
   / Dryrotted tire, can it be tubed or replaced? #9
Searchtempest is your friend. You can find descent tire deals if you are patient. Use it to get a better deal.
Thanks for the input. Oddly, the other 3 tires look great with no rot. I think the previous owner hit or rubbed something with the sidewall of hte tire causing the damage, but it's hard to tell.
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
1987 LANDALL 48ft Hydraulic Slide Axle T/A Drop Deck Trailer (A51692)
1987 LANDALL 48ft...
2012 Ford Expedition XLT 4x4 SUV (A50324)
2012 Ford...
Miles read : 112,969 (A50323)
Miles read ...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
