Drying heavy alfalfa / clover mix
   / Drying heavy alfalfa / clover mix #1
powerscol
SW Colorado
CT 235
Monday I cut 12 acres of heavy alfalfa and very heavy red clover mixed with a bit of grass. This is the second cutting. I have never seen this much alfalfa and especially the heavy red clover. In reading up I find it may take an extra 2 days to dry. I used my PZ170 to cut Monday and yesterday I ran the tedder through to spread everything out, Temps are high 80's low 90's with variable winds to 12MPH I was thinking of letting it lay for a day before windowing with my Kubota rotary rake.
Question - for my normal hay I do the rotating twist test and it it breaks at 4 to 6 revolutions I am good to go, However never having worked with the heavy red clover I am not sure what to do to check. I dont want to loose a lot of leaves so should I windrow now and let it sit another day or to or wait and windrow and bale later?
   / Drying heavy alfalfa / clover mix #2
If the weather is on you're side why not kick it at least one more time?
   / Drying heavy alfalfa / clover mix #3
I'm against that because the drier the forage becomes the more chance you have of leaf loss. I'd let it lay an extra day (tedded) and then rake it in single windrows. Like you I really like the rotary. Nice fluffy windrows that can 'breathe'. I tend to use my Delmhorst to check moisture content. I have the pronged tester where you take a sample from a windrow, place it in a plastic pail and use the pronged probe to check RM. I find the Delmhorst a tool I cannot do without. I have moisture shoes in my balers as well and I can connect the Delmhorst to the shoes and get instant readouts from in the bale chamber. They ain't cheap but ruined hay because the RM is high is always a bust too.
One thing about clover, when it dries, it will turn dark.
Update I baled Thursday afternoon with good results. Only one patch(two bales) were iffy. They will go on my cow feed pile outside the barn under a tarp. Thanks for the help.
   / Drying heavy alfalfa / clover mix #5
Careful they don't heat under that tarp.
No worries - my tarp has enough holes it in I am not worried :thumbsup:
   / Drying heavy alfalfa / clover mix #7
About the last thing I would do with hay that was baled tough is to tarp it no matter how many holes it had.
   / Drying heavy alfalfa / clover mix #8
I crimp alfalfa to reduce time laying on the ground. It save's leaves since stems drying quicker reduce's time that leaves dry.
   / Drying heavy alfalfa / clover mix #9
+1. Tarping hay invites spoilage. Holes or not. Why I round bale or store squares in the barn.
Geese folks give me a break. Its cow hay. If it gets a bit of mold so what. All the good horse hay is in the barn on pallets.
This cow hay pile is under a tarp on pallets with good ventilation and yes for the first week I check for temperature spike and had none. These are bales I would not put in the barn. The pile consists of older bales, odd size bales, bales left in baler from last run, etc. Good for cows, covering plants, bale gardens, and composting as I have done in the past etc.
BTW - if you want to compost bales, soak with water and put under a black plastic tarp. They will start cooking in a few days, then remove tarp and keep damp. This needs to be done far away from buildings as they will start smoking at some point (a good thing), but if kept damp will not combust To speed this up, throw on some nitrogen fertilizer. Turn after 3 months, then every month after. but keep the pile damp and ariated. Makes excellent compost. Before use in garden, cover again with blast plastic tarp under full sun for a week to kill any seeds that might still be in it. I had 50 bales that got rained on (soaked) a few years back and an old timer showed me how to do it. Worked great.
JOHN DEERE SKID STEER 6FT BUSHHOG (A52472)
JOHN DEERE SKID...
2023 EAST TEXAS TRAILER (A52472)
2023 EAST TEXAS...
2022 Wacker Neuson SM100 Mini Skid Steer (A52748)
2022 Wacker Neuson...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2010 Chevrolet Malibu Passenger Car (A51694)
2010 Chevrolet...
