Drum and blades
/ Drum and blades #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
Don't know how but I bent the drum around the blade holder. The protective flange. Had to use an air chisel to get it out..... Also a look at my blades after 13 hours of use...
/ Drum and blades #2
You sure do get in a lot of trouble, but then again, you seem to be using the PT a lot.
/ Drum and blades
It is the first time much of this property has been mowed. I expected damage... Just hope I am not destroying the guts of the mower in the process..
/ Drum and blades #4
Is that the brush hog mower, or the finish mower that you are using? In most things, go slow, be sure, and git -er-done
/ Drum and blades #5
YIKES!
Raise the mower wheels to the highest settings to help avoid the rocks. Also, slow down to a crawl until you have gone over the entire area and can see what is under the brush.
If its any consolation, I have destroyed a couple blades on my PT425 by bending then under a log, have broken the bolt that holds the blade on at least three times, have destroyed a rear wheel by hitting some scrap metal buried in the bushes, and I probably only have 10-15 hours of actual brush hogging. The problems is, the machine can do so much work that we tend to go too fast and run into stuff. I am convinced the brush hog is the most dangerous tool I own, with the possible exception of chain saws. :eek:
/ Drum and blades #6
My first set of brushhog blades looked similar to yours. Same situation: first time the area had been cleared let alone mowed. I can remember the blades tossing rocks that were almost 1' in diameter and over 10#. I hit plenty of rocks that wouldn't budge too.
I saved the mowpart.com site from another post here and hope at next blade replacement I'll be able to do better than PT's $50 minimum order. I'm hoping someone will need brushhog blades before me and will have figured out the part number (if there is indeed a replacement through that site).
Phil
Challenger MT400 and MT600 series tractor parts manuals (A63117)
Challenger MT400...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
2012 Chevrolet Silverado 1500 Hybrid Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
iDrive TDS-2010H...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
