Drolet Pellet Stove From Northern Tool
   / Drolet Pellet Stove From Northern Tool #1
Luremaker
Ontario
Kubota L3130HST & NH TC18
   / Drolet Pellet Stove From Northern Tool #2
I've been looking at Pellet Stoves myself. I have determined two things.
1. If/When I purchase one, it will be from a local dealer that can service the unit if needed.
2. Harman stoves appear to be the best and easiest to use and maintain. They are, however, the most expensive.
Wes
   / Drolet Pellet Stove From Northern Tool #3
Don't know anything about this particular stove, but there are a lot of unanswered questions in the information provided. But knowing what I know now, I would not buy one unless I could lay my hands on one first and answer these questions:
1. How does it draw it's combustion air? It should be from the outside, and I mean absolutely sealed from drawing inside air.
2. What is the heat exchanger surface area? you want the largest you can get. Some stoves have pretty small ones, and heat not removed from the firebox and put into the room just goes up the chimney and is wasted.
3. How many pounds per hour does it consume on it's various settings? You can use this to confirm heat output and exchanger efficiency claims(search "BTU content of wood pellets" for a BTU per pound reference).
4. How exactly is the firebox constructed and airflow controlled? This is a basic quality questions, this thing does need to contain a fire afterall, and I have looked at some pretty poorly constructed and sealed, yet nice looking pellet stoves.
5. How easy is it to access for cleaning? This is something that needs to be done weekly. A large ashpan(which it appears to have) is also nice as it only has to be emptied every few months. A small pan will need to be done more frequently.
6. How loud is it in operation? Do you want this thing blaring away in your living room while you try and watch TV?
Thanks guys, I'll do a little more research but want to make a decision soon as many of these stoves are on clearance now.
   / Drolet Pellet Stove From Northern Tool #5
Be careful of buying a pellet stove. The Wall Street Journal had an article yesterday talking about the rising cost of sawdust/wood chips. Less lumber is being produced due to the decline in houseing demand so there is less sawdust/chips. This cause the price to go up. $200 per ton.
This has effected companies making pellets, animal bedding, oil drilling of all things, and even auto manufactuers.
If you get a pellet stove it might be real hard to find pellets and when you do they might be very expensive.
Later,
Dan
2010 Toyota Prius Hybird Hatchback Sedans (A55758)
2010 Toyota Prius...
2013 Fiat 500 Hatchbacks (A55758)
2013 Fiat 500...
2013 Ford F-550 Passenger Bus (A55852)
2013 Ford F-550...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
