Driving over septic fields?
/ Driving over septic fields? #1
Frostyford
Is the BX2350/BX24 too heavy to mow grass over a septic line? I have a new septic; which means not just 4" perf pipe in the ground. It's got these 12-18" wide plastic Quansit hut style. We have five of them about 40' long. I'm going to call the builder as well, but thought I'd ask you guys as well?
Frostyford
/ Driving over septic fields? #2
A properly installed drainage bed system should be OK. However, there is a significant difference between a standard septic tank lid and the version called a "traffic lid". A standard lid (about 3-4" thick) should not have any heavy vehicles running over it. A traffic lid is 6" or more thick and will allow heavy traffic and even a driveway to be installed over the tank. If you think you will ever need a traffic lid, get it swapped out now by the builder.
/ Driving over septic fields? #3
I run over mine with a 16,000 lb backhoe with no problems. That's what the installer uses for the final grade during which he drives over it himself. I too have the plastic chambers.
/ Driving over septic fields? #4
We just had a rather long discussion on this a few weeks age. Use the search function and search for Septic to get hundreds of hits.
Bottom line is it all depends on how your system was designed. In most cases you will be ok.
Every search I've performed on this site gives me a bunch of SQL errors. I don't think its a security issue on my end.
Thanks for the info, I think I'll be ok; but will double check with the installer. Yes, the chambers is what I have. The tank, which won't be driven over is concrete and massive!!
Thanks.
/ Driving over septic fields? #6
</font><font color="blue" class="small">( Every search I've performed on this site gives me a bunch of SQL errors. I don't think its a security issue on my end. )</font>
Did you read the bright red banner at the top of the page? You have no security issues. An upgrade is taking place. Just be a little patient.
1998 PITTS LT-40-8L 4 BOLSTER LOG TRAILER (A64276)
1998 PITTS...
ASV RC85 Skidsteer (A66285)
ASV RC85 Skidsteer...
1996 Sunflower 1543-38 Folding Disk (A63688)
1996 Sunflower...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A59823)
2018 FREIGHTLINER...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
211453 (A62131)
211453 (A62131)
