Grading Driveway upgrade work during brutal NY winter
   / Driveway upgrade work during brutal NY winter #1
450EXC
Central NY
Kioti CK30
Yes, the CK30 performed flawless even in early January. The tempature peaked at 62*. The winds were 3 mph with gust up to 5 mph resulting in wind chills at, well, 62*.
I upgraded a section of driveway near the barn with fabric and new gravel. The old driveway was grass with maybe some 100 year old stone under it. It got pretty muddy in the spring and fall.
I wanted to raise the level of the drive so I placed the fabric right on top of the grass. I dug out where it met the existing stone and the high side.
   / Driveway upgrade work during brutal NY winter #3
Your joking right:D 62 being brutal:confused: I am sure that tractor will handle temps well below 0.
murph
Finished for now. I want to reroute the lower section and need to add some fill to the new location first.
Uhhh, Yeah Murph, that was a joke. So was the 5 mph wind chill.
The tractor works fine at 0*, although there is some whinning noise coming from the operator.
   / Driveway upgrade work during brutal NY winter #6
Evening 450EXC.
Yeah those kinda temps makes one want to get a jump start on there spring projects....looks like another week of above normal temps.
I also upgraded the drive down at the sawmill. It's like summer, I'm way ahead of schedual now.
   / Driveway upgrade work during brutal NY winter #8
Nice project. Here's what I've been doing with my Driveway for the past couple of days... Yesterday the DK40 fired right up at a balmy +10F. This morning I got to do it all over again as last night's wind put 12 to 18 inches back on the drive. Tonight the wind is blowing again...
   / Driveway upgrade work during brutal NY winter #9
450,
I heard the fabric went up a whole lot in price. What was the name of the stuff you used and if you don't mind me asking how much per yard?? Thanks..
I'd rather pay the price for the fabric then watch all the rocks and stones disappear every year..
I called around in Syracuse and Utica and all were about the same price for fabric.
353.00 + tax = 385.00 for 12.5' wide x 432' long. About .90/ft or 2.70 a yard. That was on 12-14-06.
I'm not sure of the name, the invoice says GS-126R-600 / TER 12.5x432 Stabl Fabric. All said it was the DOT spec grade for the highway builders. I found some lower grade stuff but it was only a little cheaper, maybe .80/ft. DOT spec seems a little overkill for my little driveway. My gravel guy calls it Marified paper or geotextile. Crusher run was $ 60.00 / 10 ton delivered by my buddy, cheap.
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
2016 BMW X5 sDrive35i SUV (A50324)
2016 BMW X5...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52748)
2003 International...
MCELROY PIPE FUSION MACHINE (A52472)
MCELROY PIPE...
44509 (A51692)
44509 (A51692)
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
