driveway protection from blade?
   / driveway protection from blade? #1
bucktaker
Platinum Member
Sw Ohio
Kubota L5740
Hello
With the recent heavy wet snow my blower (woods 6215 mower with grasshopper blower) was useless as it clogged no matter what I did. I got out the L5740 Kubota and made short work of it.
I dislike using the tractor cause I always leave scrap marks on the blacktop coating. What have others done to prevent this? Thinking of maybe a hardwood edge attached to my bucket?
   / driveway protection from blade? #2
Almost anything attached to the bucket will prevent marks on your driveway. Usually, the issue is how it gets attached and if you have to drill through bucket. There's a sticky thread at the top of this forum of a commercial solution and there are plenty of threads about other solutions, from wooden planks to plastic pipe.
   / driveway protection from blade? #3
I just use the blower or bucket edges in contact with the blacktop. Marks don't bother me.
   / driveway protection from blade? #4
How about a thick rubber blade in place of your cutting edge
   / driveway protection from blade? #5
Piece of conveyor belt bolted to the edge works great. You can find it at Tractor Supply or if you know anyone at an old mine or manufactureing facility you maybe able to get a piece from an old belt they are pitching out.
   / driveway protection from blade? #6
I seen somewhere on the internet they had a hard plastic that attached to the buckets cutting edge. It was yellow with like 5 screw bolts the stuck up.
   / driveway protection from blade? #7
There's a sticky thread at the top of this forum.
   / driveway protection from blade? #9
   / driveway protection from blade? #10
Here is what I use. It came off a county highways plow.
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
TEST BID LOT (A50775)
2018 Chevrolet Camaro 1LT Coupe (A51694)
2018 Chevrolet...
Unused Delta Crash...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
