wmonroe
Elite Member
I see in the first picture that there is a lot (relatively) of snow in the lower area. I have problems with drifts in my driveway where it is lower. You might want to consider which direction the prevailing winds are when it snows, and over winter when it doesn't. Raised a bit extra will likely leave it clearer.
The snow drifting is a concern i have and the long term plan is to plant at least two rows of trees on the wind side of the driveway. Raising the driveway a bit is a good idea, hopefully between that and some snow fence I can keep the worst of the drifts off.
hello i have a 1000 ft gravel driveway, all i did was dump the gravel down i graded it about 6 to 8 inches deep no fadric never got any weeds i mow the sides so grass dont grow in. here we have quarry prosses its 3/4 stone mixed with stone dust it packes like concrete after a while.
Did you grade the topsoil off or did you just put the gravel right on top of the ground? How has your drive held up? Has there been any large trucks on it, cement trucks or tri-axles?
Thanks for the replies
