oldgrizzlybear
Bronze Member
The culvert under my drive is rusting out. This is a fairly large culvert approx. 2 feet in dia, and about 26 ft long. What I would like to do is sleeve a slightly smaller plastic culvert inside the existing culvert. This should still give me enough capacity. I'm wondering if the switching from galv. metal to plastic culvert will have the same effect as with water pipe: you can go one size small and keep the same flow. Has anyone done this? Any advice would be appreciated.
Larry
Larry
