Rotary Cutter driveline shield & bearings
/ driveline shield & bearings #1
thartson
Schulenburg, TX
John Deere 4105
I have a John Deere 4105.
And a Land Pride RCR 1860 5' rotary cutter attached.
Two easy questions for which I am stumped...the owners manual is useless as regards...
(1) is the grease fitting for the driveline shield bearings the plastic nipple at the end of the shield in front up by tractor & back near cutter? I couldnt get the grease fitting to snug over it
(2) how to remove the driveline shield?
I'm a new owner, very savvy with this stuff but a bit lost here.
Thanks - Tyler
/ driveline shield & bearings #2
Thanks - Tyler
The plastic nipple serves as a reminder that there is a zerk in there to grease, rotate the plastic shield to line up the hole in the shield to the grease zerk on the shaft, both front and back ... to remove there are some clips where the larger part meets the smallet part, push them in.
/ driveline shield & bearings #3
Read page #25 of your manual. easyest if drive line is unhooked from tractor, Take the tractor end and swivel it around to find zerk and with end to one side it is easy to grease it in this position. Same with the other end, but would be easyer if driveline was unhooked from gearbox. hope this helps
17in. Bucket w/ Teeth Excavator Attachment (A64194)
17in. Bucket w/...
2008 GMC 3500 HD 4x4 Ext. Cab 9Ft. Flatbed Truck (A64194)
2008 GMC 3500 HD...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
New/Unused Landhonor Tree/Post Puller (A65583)
New/Unused...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
New/Unused Quick Attach Pallet Fork Frame (A65583)
New/Unused Quick...
