Oil & Fuel Drive System Fluid Plus
/ Drive System Fluid Plus #1
Bob_Bainbridge
Platinum Member
NE Ohio
Boy, I got a shock today when I stopped at my local dealer to buy a gallon of synthetic Drive System Fluid Plus for my 3235. The last gallon I bought a couple years ago was in the upper $30 range. Today it was $48 with tax. I couldn't find it on the shelf with all the other oil and went to the counter to ask where it was. I then saw it behind the counter. When I paid for it I found out why they keep it behind the counter.
Bob B.
P.S. Maybe we're starting to pay for the Gulf spill already!
/ Drive System Fluid Plus #2
Ouch.
When I get back home, I have to do my 50 hour servicing on my;
1. 7532
2. 5234
3. 1046
Not to mention the F350 is due another oil change in a few thousand miles...and I use amsoil. 15 quarts....AND.....probably need to change tranny fluid, from heavy towing...also amsoil.....:(
what was it you were complaining about...? :laughing:
Update to old thread. Last time I changed the transmission filter on my 3235 it was warmed up to facilitate the engine oil change. I jacked up the front and had the new filter gasket all lubed and ready for a quick install. I ended up losing about a pint of oil. This time I didn't start the tractor (hadn't run for a day or two). I jacked the front up as high as possible, got the new filter ready, removed the old one and NO oil came out so I didn't have to add any. I then warmewd the tractor up and proceeded to change the engine oil and filter.
Bob B.
/ Drive System Fluid Plus #4
I learned the 'jack up the front' trick some years ago when I did the initial trans filter change on my 2544. I spun-off the factory filter only to discover my replacement was over on the work bench. I lost a gallon of CC Drive Sys Fluid Plus in the process into my dirty drain pan.
I personally wouldn't pay more than $4 a quart for the Cub stuff with Rotella 15w40 available (or brand of your choice). That's a whole'nother topic though.
I only purchased the Cub stuff once (first trans oil change). It was $36-38/gal back in 2005.
Joel
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
Freightliner Columbia (A63689)
Freightliner...
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
Cub Cadet MOWER (A64557)
Cub Cadet MOWER...
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
