Rotary Cutter drive shaft to gear box problem
   / drive shaft to gear box problem #1
jop
Western NY
Kubota L3400
Hi,
I have a woods BB60 on a Kubota L3400. The other day I was mowing and the shear bolt came out of the shaft. It didn't shear. As a matter of fact, the bolt was in perfect condition and I am able to reuse it.
My problem is that the PTO shaft came forward about the width of the bolt and I can not seem to get it to slide back to replace the shear bolt. There is a slip clutch on the unit.
I have tried to drive it back with a sledge, but it doesn't budge. I soaked it with WD-40.
I am at a loss.
THANKS in advance for any suggestions.
Jim
   / drive shaft to gear box problem #2
The last time I had a tough one to deal with I put a large pipe wrench on it so that I could get a good hit on it. Sometimes it takes a lot of preserverance and persuasion.
   / drive shaft to gear box problem #3
I would try and take it completely off and see if I could tell why it will not slide back on.
   / drive shaft to gear box problem #4
I agree, I would already have put this driveline in a large vise to work on it. Not a good idea to put strain on the tractor pto shaft if avoidable.
   / drive shaft to gear box problem #5
Hi,
I am at a loss.
Jim
Sounds like it may have spun enuf to cause a gall/spot weld. With lots of lube on the joint see if you can rotate it back and forth against engaged driveline resistance. If not try a very quick brief engagement of the pto. Hopefully itll spin free.
   / drive shaft to gear box problem #6
... the bearings will all thank you if you take the shaft off of the tractor & the implement before commencing to wail on it.
   / drive shaft to gear box problem #7
When you do get it separated, drill and tap a grease zerk on your yoke so the next time it shears, you will have a greased surface for the yoke to spin on.
Ounce of prevention.
   / drive shaft to gear box problem #8
Hes working on the implement end.
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
3 pt Finishing Mower (A50514)
3 pt Finishing...
5' ATV Harrow (A50515)
2023 JOHN DEERE 30P TIER EXCAVATOR (A51242)
2023 JOHN DEERE...
2006 HONDA RECON 250 FOUR WHEELER (A51243)
2006 HONDA RECON...
2004 Caterpillar 345B Hydraulic Excavator (A50322)
2004 Caterpillar...
