DRIVE SHAFT LEAKING
   / DRIVE SHAFT LEAKING #1
warrior1942
yanmar 1700m
Jd 4400 frond end loader 4wd 2001
The front drive shaft is leaking fluid, the leak is directly above the power steering lines. If anyone has any suggestions on how to repair they would be greatly appreciated.
   / DRIVE SHAFT LEAKING #2
:welcome:
Will look into that on the CD tech manual, if someone doesn't get back to you sooner.
I have the 4300 and am not sure where this fluid is coming from, but may be from the hyd. fluid cooler ahead of the radiator. Might check that out, and be sure the battery hasn't gassed the fins and caused corrosion and a leak. The distance between the battery and the fins are very close and if the battery isn't capped so the off-gas is tubed down below the battery, it can cause corrosion of these fins.
Thanks, will check that out. Where can I order a shop manual cd. Again thanks, any and all help is appreciated.
Thomas
   / DRIVE SHAFT LEAKING #4
Your Deere dealer to get the CD. Or on eBay if that is comfortable for you.
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
1999-2010 Ford Pickup Truck Bed (A52377)
1999-2010 Ford...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2015 Ford F-550 4x4 Knapheide Service Truck (A51692)
2015 Ford F-550...
UNUSED Safety Work Gloves (A53117)
UNUSED Safety Work...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A52706)
2018 GENIE GTH-636...
