Hello all,
I have a 2002 Murray lawn tractor (model number 465622x99A, Badged "Ranch King Elite", 46" cut, 18HP) and the drive belt snapped a few weeks ago. The model is not quite the same, but the looks are very similar to this one Murray, Inc.
I bought a replacement belt but when I got under to install it I noticed there is a difference between the routing diagrams in the manual that came with the mower, and what is actually in the mower! My manual shows a routing where the belt comes from the stack pulley, then connects a V-idler pulley, and then connects to a Rear-idler pulley that regulates the tension on the drive pulley. However, mine has a an idler-assembly that looks entirely different, since the flat-idler is first, and then the v-idler, which causes the belt to rub wit a metal bar. The picture below shows the parts and the current routing
I tried rotating the idler arm but it doesn't work. I also tried to swap the pulleys, but they are different diameters and don't fit the arm. What am I missing?
Thanks!
G
Thanks!
G
