Drilling steel.
/ Drilling steel. #21
ray66v said:
The whole blowing up thing aside, 2 alternate methods to a 1 1/4" drill would be:
1. A cutting torch or plasma cutter followed by a die grinder with a carbide bur.
2. Mark a circle and make a series of progressive small holes, (low speed drill with cutting oil), along the line followed by the die grinder with a carbide bur.
Both methods will be time consuming.
That ain't no $$$$, chain drilling a hole in thick metal is very time consuming.
A jig saw with a metal cutting blade also works after all your holes are drilled....then dress up with the high speed rotary file.
/ Drilling steel. #22
I not sure a jig saw will make a circle that tight (1 1/4") in thick metal?
Then you have to make bigger holes so the blade will fit in them too.
BTW, Home Depot sells Rigid Hole saws with a LIFETIME guarantee, (I think there nuts), they once assured me that if I burn them up all I have to do is return it to the customer service desk. They will then replace them no questions asked. If you don't already own one or need to replace the one you have after a hole or two, that is the way to go.
/ Drilling steel. #23
biggerten said:
Technically, it will sublimate, going from a solid to a vapor. Evaporate is going from a liquid to a vapor.
Yawn, I must be bored to correct such a penny-enny thing.
I am bored! The correct term is "penny ante" I believe.
/ Drilling steel. #24
Water is a cheap way to purge (don't cut at the very top where air pockets might be), but I prefer an inert gas like argon or carbon dioxide. I would probably go with plasma or oxy/act for cutting the hole just for speed. Either way I doubt the tank is 3/8 thick, even your 2500psi tanks are not that thick and propane pressure is 1000's of psi less. A 1 1/4 inch bi-metal hole saw will need to run around 200 rpm +- and a mag drill will be more difficult than a hand drill, unless your tank has flat surfaces.
/ Drilling steel. #25
I'd suggest using a RotoBrute carbide hole saw.
Fresno Oxygen / Barnes Welding Supply
I have several of them. They cut really fast and make a smooth hole with no burrs. Worth every penny if you're having to make multiple holes.
/ Drilling steel. #26
Hahahah! I stand corrected, sir!:D
And you put it so well, I didn't even mind the well deserved boot in the pa-toot!
/ Drilling steel. #27
And here I thought Penny Ante was a pricing game played on "The Price is Right"....;)
/ Drilling steel. #28
The one I cut was at least 5/15" thick. It is still a pressure vessel and needs to withstand the water/pressure displacement test thingy.(hydro test)
David from jax
/ Drilling steel. #29
tuolumne said:
Are you suggesting that I could hook up the dust collector to an outlet while welding? It will move about 1400 cfm through an 8" hole. The 2" outlet would slow that down a bit.
You need good fresh air turbulence in the heated area and as much of the interior volume as possible. I think you will be able to move a couple hundred CFM thru the 2" hole. Normally going down a factor of 4 in diameter would limit delivery to 1/16, but I assume the 2" flowpath will be very short and therefore much less limiting.
larry
/ Drilling steel. #31
As i have done in the past . Scribe your circle with your plug as a guide . Use a 3/16 drill bit and drill holes just to the inside of the scribed line and as close as you can to each other. A hole that big will take 10-15 minutes to complete . knock the centre out . A quick cleanup of the hole and your ready to weld the plug in , the weld will cover any little notches without a sign of them being there . Almost impossible to create a spark especially if you use some soluble oil mixed with water whilst drilling . If you use a hole saw be sure to drill the pilot hole first . If you do'nt , when you learch forward when the hole saw drill breaks through the teeth on the saw will grab and you will brake the pilot drill every time .
/ Drilling steel. #32
So in a related question.....how would I drill a 1-1/4" hole in 1/4" steel plate that is covering my well opening? Simple hole saw? Also, this is out in the middle of a field with no power source. Will a portable drill have enough umph to cut this one hole?
THX
/ Drilling steel. #33
THX
High quality new holesaw, and my 18V dewalt cordless or my 19v Craftsman and a couple batteries.
Take you longer to set up and get going then to do the actual drilling.
Hi quality, sharp (new) bi-metal bit will make it go easy.
/ Drilling steel. #34
Thanks Al. I did not want to pull the cover and bring it into town to drill. Safety issue leaving the well exposed, etc... Will give the battery packs a work out now.
/ Drilling steel. #35
Maybe a portable generator or an inverter for your tractor,truck, vehicle and an electric drill.
2009 Volkswagon Jetta Sedan (A61574)
2009 Volkswagon...
2025 40in Tilt Bucket Excavator Attachment (A61572)
2025 40in Tilt...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
Rooster Weathervane (A61574)
Rooster...
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
