drilling holes
/ drilling holes #41
"Just wondering how thick of metal can be practically drilled with a bimetal hole saw."
I've cut holes in steel up to 1/2 inch thick with a hole saw without any problems. Takes some patience and a lot of lube, but it was easy and made a perfect hole.
/ drilling holes #42
I have been using a mixture like this for many years, but did not realize this is what CNC drilling use.
Quote
A typical CNC usually uses emulsified coolant, which consists of a small amount of oil emulsified into a larger amount of water through the use of a detergent.
So, maybe a 10 to 1 ratio of water to oil, and 2 tea spoonfuls of Dawn detergent. Shake the mixture p real good and you are good to go.
/ drilling holes #43
Quote
Interesting, thanks.
I would also add that you can blue the drill bits when sharpening them, I just use straight water in the water troth on the grinder to keep them cool.
JB.
/ drilling holes #44
WD40 or any lubricant oil should never be used. You want to CUT not lubricate. The only benefit would be to cool the drill bit using lube oil. The down side is that lube oil has extreme pressure additives to prevent ware.
Not sure I completely agree: you want two things from the cutting fluid: coolant as described...and, friction reduction. Cutting is actually the use of that "inclined plane" we learned about long ago: that's how a chisel or a wood plane works and that's how your drill bit works. That's how a woodscrew works and using beeswax or soap on the screw dramatically reduces the effort to screw it in. Heat in the woodplane or screw is not typically a problem (but can be in a power saw), but in metal work it is a bigger problem: higher heat and the possibility of changing the temper of the bit and/or hardening the material to be drilled.
So, even WD40 can help, but there are much better, specially formulated products for the purpose; if getting the liquid to the site is a problem, there are also creams or waxlike products.
Now, a bit of cocktail party conversation: why is it more effective to "slice" with a knife, rather than just push straight down (think, tomato)? Because you are reducing the angle of the inclined plane ...just like zigzagging up a mountain ...(and, that's why some woodplanes permit the blade to be canted a bit.)
Sorry for the physics lesson, but the important take-away is the use of some fluid/cutting aid when drilling metal.
/ drilling holes #45
Joel, would you use cutting oil in your car or tractor?
/ drilling holes #46
My experience is similar to Runner's... 1/2" is the max I can get with my small bench top Delta drill press. I wish mine would run slower.
I love the quality of the hole created by a hole saw, though. I've even sharpened a hole saw with a die grinder late at night when I only had a few more holes to cut. It's not near as good as a new one, but it gets through the metal and moves me on to the next step without having to wait another day and make another trip into town.
I have poor luck with the lifespan of a hole saw. If I get a dozen holes out of one, I'm lucky. I do use cutting fluid, but maybe not enough. I try to keep the "well" created by the kerf full of fluid. I am planning to try the putty pool trick in the near future, though.
/ drilling holes #47
only as a last resort ...
I probably didn't say it correctly but reducing friction is one of the objectives, second to cooling ...and, in fact, reducing friction reduces heating and thus...
Water can, by itself, can reduce friction: witness how ice skates work or why the slipperiest ice/snow is around 32F ...and, adding a surfactant (like a dish detergent) makes the water "wetter" so it works even better.
As I also tried to say, and as many of you said, there are specialty products which do the job best ...some choices dependent on the material being machined. ...I am partial to the products of Tap Magic Metal Cutting Fluids
But, I enjoyed your question of whether to use cutting fluids (or WD40) in an engine ...thnx, joe
/ drilling holes #48
This link shows the RPM formula I was taught to use.
Calculating Cutting Speeds for Twist Drills
As for cutting fluids, I like to use products that were formulated for the job even if nothing more than Rigid thread cutting oil. An easy application method is to hold a small oil saturated brush against the drill bit as it rotates.
To avoid serious injury, clamp the work to the press table when using larger bits on some applications. You be the judge there.
/ drilling holes #49
Yes, use the right tool for the job. I always clamp the work to the table. All ways.
/ drilling holes #50
I have bored out 3.00" holes x 2" thick but it takes some doing.....Using a milling machine with coolant and a wet/dry vac to pull the chips out of the groove is the trick......if you don't pull the chips fairly often, then if a tooth breaks off it trashes the hole saw in about 2 seconds.....:mad:
It's doable but needs to be slow and cautious, and oh yes they need to be quality hole saws......
/ drilling holes #51
Amen!
A chunk of steel stuck to a bit rotating at 400 RPM is scary.
/ drilling holes #52
I came across this while searching for cutting fluids.
Drill Bit
Lubrication Method
Squirt Bottle ----------------------------2
Hose -------------------------------------3
Clay Dam ------------------------------ 4
Under Water ---------------------------4
Squirt Bottle w/pumping action ------6
Clay Dam w/pumping action ---------10
Under Water w/pumping action ---- 10
Water Feed ----------------------------10
Rating
(1 poor - 10 good)
/ drilling holes #54
i bought a Rigid oiler years ago, and it works great..but messy. I like your idea of the oil soaked brush. i think im going to try that next time i use the drill press
/ drilling holes #55
I cant imagine a home setup, even on a good solid drill press or mill that would drill a 1" hole well at 400 rpm in steel. 100 rpm or slower works well.
larry
/ drilling holes #56
Has any body heard of a Hanson Heavy duty drill press? I have been searching and can't find any information about them.
/ drilling holes #57
I was just wondering how long it should take to drill a hole in 1/4". I have some harbor freight silver and deming metal bits. To cut 3/4" hole on my drill press at 300 rpm's it took about ten or more minutes each hole. Is that about right?
I drilled 8 x 1-1/8 holes in 1/2 inch plate from a 7/8 pilot in 20 minutes it took me longet to pilot from 1/4 to 1/2 to 7/8 but not by muchsay all in an hour and they are matched holes in four different plates.
Did you pilot your holes with a smaller bit? If you did your bit must be dullllllllllllllllllllllllllllll
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63688)
2012 MACK Tender...
2006 KAWASAKI BAYOU 250 ATV (A60430)
2006 KAWASAKI...
John Deere 4040 Tractor (A64047)
John Deere 4040...
Caterpillar Traxcavator parts books (A63117)
Caterpillar...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
