Drilling holes in metal?
   / Drilling holes in metal? #11
Bird, I have 3 of them still in the blister packs, some day, I too will find a use for them. Didn't buy them though, I found a tool box in the gutter with the bits and a complete tool set for drilling (cutting) holes in sheet metal, ie circuit breaker boxes....ain't used it either! I do have a 1" unibit (#21?) that I used years ago for drilling holes in auto floor boards for wiring installations.
   / Drilling holes in metal? #12
RPM,
Quit blowin stuff up. /w3tcompact/icons/laugh.gif A Plasma Cutter is faster, easier, safer and almost as showy.
SHF
   / Drilling holes in metal? #13
The UNI bits really shine when used in thin (<1/8") metal. They cut the hole without the binding and deforming that regular drill bits cause. You will end up with a burrless hole and flat metal on each side of the piece. I bought my first one at an electrical supply store - they sold it to drill though electrical panel boxes.
   / Drilling holes in metal? #14
Yeap on the thin stuff they are nice.But I've used them on stuff up to 1/4" thick.Just keep in mind you may need to drill from both sides to achieve a nice clean hole on thicker materials...
Lil' Paul
Proud owner of TC21D
Laziness is the Father of invention.../w3tcompact/icons/laugh.gif
   / Drilling holes in metal? #15
For thin metal, unibit gets a 100!, 1/8" to 1/4" a hole saw, lthicker gets a twist drill.
A "silver and deming" type twist drill bit is larger than 1/2", but has a shank turned down to 1/2". They work best in a drill press, but a 1/2" drill motor will work OK. Keep your drill motor speed very slow, and use oil. I drill in steps of about 1/8, 3/8, 1/2, and then the silver and deming size. I have no problems with 1" dia. holes in 1 1/2" thick draw bar material.
The max RPM speed you should operate a lubricated HSS drill bit or hole saw in steel is 320 divided by the tool diameter, so 640 RPM for a 1/2" bit or 80 RPM for a 4" hole saw, etc.
Harbor freight sells a lot of very low cost tools. I got my S&D set 9/16 - 1" for about $20. I got what I paid for, but can drill holes and have not broken a bit yet.
Dewalt 14" Chop Saw (A59076)
Dewalt 14" Chop...
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
JRB 90" GRAPPLE BUCKET (A58374)
JRB 90" GRAPPLE...
Set of Heavy Duty Steel Trailer Ramps, 60" Long (A59076)
Set of Heavy Duty...
(INOP) YAMAHA GAS GOLF CART (A58374)
(INOP) YAMAHA GAS...
LOT: (4) Pairs of Tire Chains, Fits Tire Sizes: 11R-22.5, 285/75-22.5, 295/75-22.5, 275/80-24.5, ... (A59076)
LOT: (4) Pairs of...
