Drilling 1/4" and thicker metal with a hand drill
   / Drilling 1/4" and thicker metal with a hand drill #1
NCMau
NC
MF 202/Ford 8N
When it is not possible to use the drill press for making a hole in thick metal, I have to use the hand drill . Even when I make a pilot hole, use lubricant and step-up bit sizes, it is sometimes hard. I remember seeing years back some sort of drill assist jig that would help applying pressure while drilling. I can not remember if it was manufactured or homemade. I tried to Google it but I can not come up with anything. (I am not talking about magnetic drills, that would be the holy grail).
It could be a simple strap applying pressure while drilling. Are you guys aware or using anything that would facilitate the hand drilling? If you do please share it.
   / Drilling 1/4" and thicker metal with a hand drill #3
If I can't finagle a mobile or small bench press into position I usually borrow a mag drill and use an annular cutting bit...
   / Drilling 1/4" and thicker metal with a hand drill #4
Sometimes I've used a bar for leverage against the side handle.
A chain hooks onto the metal to be drilled and the pry bar.
Lay it across the side handle and press down.
Works even better if a small pipe is welder to the pry bar to slip over the side handle.
This works down and horizontal (truck frames).
For drilling up into truck frames I've used a floor jack.
Jack up about an inch (suspension travel) and let her rip.
   / Drilling 1/4" and thicker metal with a hand drill #6
Before I got my mag drill, if there was room to get BEHIND what I was drilling I'd use one of these
IRWIN QUICK-GRIP One-Handed Bar Clamp, Heavy-Duty, 24", 1964714 - Quick Clamp Spreader - Amazon.com
one pad goes behind what you're drilling, other goes behind the drill motor IN LINE with the axis - one hand holds the drill, other hand squeezes the clamp handle.
I got the mag drill before building a little "bridge" that'd mount in place of the pad to keep from drilling holes in the CLAMP... Steve
(edit) - And THEN, you hold the AIR HOSE in your TEETH, aimed at the drill bit (liquid coolants are too messy :laughing:)
   / Drilling 1/4" and thicker metal with a hand drill #7
I need to drill three 5/8" holes STRAIGHT through my 7" bench top to mount my vise. I didn't want to use lag bolts as the vise weighs 157 pounds.
I picked up these two drill press devices (one Craftsman the other Black and Decker) today for $5 each. I'm hoping one of them will help to keep the holes perpendicular. Something like that MAY work for you?
Otherwise as others have mentioned, it's pretty hard to beat a mag drill for steel. I only purchased mine lately, but I wish I had done it 40 years ago. :(
Keep in mind though you will probably need an arbor adapter and Jacobs type drill chuck for holes UNDER 7/16" as the smallest annular cutter will be around 7/16".
   / Drilling 1/4" and thicker metal with a hand drill #8
Adapt one of those so it can drill through the base, if not already able. Then clamp or ratchet strap it into position. You could make different shape bases for a job if needed. You could use a ratchet strap to apply pressure, too, as long as the drill holder keeps it at 90 degrees to the work.
Bruce
   / Drilling 1/4" and thicker metal with a hand drill #9
Bruce
Bruce:
The Craftsman base already has a hole through the base that will allow my 5/8" bit to pass through. I thought for 10 bucks I'd find some alternate uses for them in the future.
Before I bought my mag drills I turned the headstock on this cheapo drill press 180 degrees and clamped it like you were suggesting.
   / Drilling 1/4" and thicker metal with a hand drill #10
sharpen your bits
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
Electric Concrete Mixer (A51573)
Electric Concrete...
1/4 '' Wolverine Universal Quick Attach Mount Plate (A51573)
1/4 '' Wolverine...
INSPECTION (A51573)
INSPECTION (A51573)
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
