Drill Chuck
/ Drill Chuck #1
Todd NE WY
North East WY
JD 4320
Not sure if this is the right place for this but it is a repair and without it I can't work on the tractor.
I need to get the chuck off of a 1/2" craftsman drill. Took the retaining screw out but I cannot get the chuck to screw off. Does anyone have any sortcuts or hints to get it off? Counterclockwise is the correct way to take it off right?
Thanks
Todd
/ Drill Chuck #2
It may be a compression fit. Tap it a few times with a wood or plastic mallet and see if that does it for you.
/ Drill Chuck #3
Todd, I'll assume yours is close to the same as my 1/2" Craftsman hammer drill. The retaining screw is left hand threads; loosen by turning clockwise. But you say you already have that out. The recommended next step is to insert the small end of a 5/16", OR LARGER, hex wrench into the chuck and tighten the chuck onto it just as you would tighten a drill bit in it. Then with a mallet, strike the long end of the hex wrench to loosen the chuck, and yes, it's right hand threads; i.e., counterclockwise to loosen. In other words, you need a sudden impact to loosen it.
/ Drill Chuck #4
Bird you amaze me with the good advice you give on here all the time. I never thought of that. I was going to suggest That he put the chuck key in it and hit it with a soft hammer. I wish every one on here always gave (good advice) like you all the time. Keep up the good work.
Charlie
/ Drill Chuck
Thanks for the advice. I would have never thought of the allen wrench. I tried hitting the chuck key but it wasn't effective at all. The allen wrench worked great 2-3 hits and it was loose.
Thanks again,
Todd
/ Drill Chuck #6
I used that same approach to get the 3 jaw chuck off of my Atlas/Craftsmen 6" metal lathe. One whack with a soft blow hammer and the chuck was loose. I had spent quite a bit of time fussing around with other ways to get the chuck off before I tried the allen wrench technique. Of course the wrench I used was a 3/4". :D:D:D
Vernon
/ Drill Chuck #7
Charlie
Ditto that!!
ZINGER BY CROSSROADS BUMPER PULL CAMPER (A67714)
ZINGER BY...
1 PALLET OF JACK & IMPACT GUNS (A66091)
1 PALLET OF JACK &...
2013 FORD F-550 SUPER DUTY (A67714)
2013 FORD F-550...
2018 MACK LR 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR 6X4...
Generac SD135 136kVA Standby Diesel Generator (A66734)
Generac SD135...
CHANDLER 500 BBL FRAC TANK (A67714)
CHANDLER 500 BBL...
