Drawbar Stabilizer
/ Drawbar Stabilizer #1
branman1971
Texas
Yanmar YM1700
I got a drawbar with the 1700 but there is no stabilizer to keep the tow ball from flipping around upsidedown. Also, when I was moving my pontoon boat the tongue was swaying like crazy side to side when backing it up. If my Dad will bring his welder back over I can build one I think. Anyone know of a quick fix/temporary solution?
/ Drawbar Stabilizer #2
I presume that by "drawbar" you mean a bar with a bunch of holes in it that goes between the 3pt arms? If so, get a clevis and put it over the end of the arm and pin it into the first hole of the drawbar. That will stop almost all of your rotation.
Aaron Z
/ Drawbar Stabilizer #3
What you have is not really a drawbar.
A real drawbar usually attaches below the differential is is the proper hookup point for a hard pull. It is engineered to prevent the tractor from flipping over backwards if an immovable object is pulled on hard.
The tow bar you have is convenient for hooking up trailers and carts, but if you use it as the hookup point for pulling on something like a stump or a large rock, you are taking a large risk of overturn.
/ Drawbar Stabilizer #4
You need a draw bar lock, and a set of anti-sway chains, or adjust yours. Tractor Supply has it for $20.
Aaron Z
Yep that's what I got. This sounds like a good fix. Thanks.
/ Drawbar Stabilizer #7
You can also use the clevis to pull a chain that way. IIRC, it was cheaper or about the same money to get a clevis as to get a thing made to keep the bar from rotating at when I was looking at TSC.
Aaron Z
2014 HIPOWER 310 GENER (A67714)
2014 HIPOWER 310...
2017 Ford Escape SUV. (A66738)
2017 Ford Escape...
2019 PETERBILT 567 (A67714)
2019 PETERBILT 567...
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
Unused 2023 Monroe-Tufline DS1120T 10ft. Hydraulic Box Scraper Tractor Attachment (A66734)
Unused 2023...
2019 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A66736)
2019 Peterbilt 579...
